Tractor Talk Discussion Forum
Any thoughts on sandblasting?
Chris
07-12-2004 16:17:14
I have an old John Deere that I was going to have sandblasted. Anything to watch out for or anything to do before I take it to the guy? Thanks for your help.
farmer dave
07-15-2004 15:16:59
 Re: Any thoughts on sandblasting? in reply to Chris, 07-12-2004 16:17:14
I thinking of taking the wheels of my old ford and having them blasted. Of course, I'll have the tires removed. That would be all right wouldn't it?
Carla
07-13-2004 12:41:54
I'll concur with the prevailing opinions..... .please don't destroy your tractor by having it sand-blasted.....unless..... .you have it completely stripped into bare components, protect any machined surfaces with duct tape, and are willing to do very extensive cleaning to remove all traces of abrasive, including cleaning out all the tapped holes.
(the old books on industrial manufacturing techniques explain the use of huge "washing machines", using boiling-hot water and strong detergents like a household electric dishwasher but of a much larger and more powerful size, to remove all remaining traces of the foundry sand from castings, after the machining is done, before the parts go to the assembly floor.)
I've never restored an old tractor, but I've restored quite a few smaller items of old machinery, and have glass-bead blasted literally thousands of old castings, over the years ...
It is quite easily possible to make cast housings look "factory new" with abrasive blast cleaning, and replication of the original paint finish..... but.....sand, or any other abrasive media, will be forced into all the little "nooks and crannies" of the castings....every last trace of this material must be removed, or the oil will pick it up, and carry it directly to the gears and bearings, with the obvious result...
Sand-blasting can work very well on removable sheet-metal parts, or, for that matter, on the generality of cast iron or formed/fabricated steel parts other than housings carrying internal components which run in oil.
That said, there is "no free lunch" with sand-blasting..... .blasting thick heavy iron or steel parts is "self-explanatory", right enough, but blasting thin sheet steel components like fenders or engine-shrouding is not easy..... the sand-blasting media and technique used for blasting iron bridges and brick buildings will destroy sheet-metal parts beyond repair in a matter of seconds.....
There is an easy way to clean up thin sheet-metal parts without warping or embrittling the metal, and i've done quite a bit of this, one time and another, on such items, as, for example, the shrouding for the little Wisconsin air-cooled engines....first, use a strong paint-remover, and apply plenty of it. I use one or another make of "aircraft epoxy stripper"...its not cheap, but the time saved makes it cost-effective.
After allowing plenty of time for the remover to act, and then dry, blast the parts with medium-grit glass-bead media, taking care to use a relatively low pressure, say 30-ish-40-ish lbs of air at the nozzle, and running the media stream at about 45deg to the work.
The old paint, with its "body" and "adhesion" destroyed by the stripper, will come "flying off", revealing clean steel and rust spots..... go over the rust spots til they come clean, taking care to run the abrasive stream from different angles, and avoid steady blasting in any one spot for more than a second or two.
Done carefully, this technique will leave the sheet-metal parts nicely cleaned up with no warpage or embrittlement whatever.
If the sheet-metal had significant rust-pitting, the glass-blast will sometimes not remove quite all the active rust from the pits..... go over the work with a phosphate "metal-prep", well "scrubbed-in" with a fine wire brush, to neutralise the remaining rust, clean the metal well with lacquer-thinner, then use an "etching-primer", followed by a "sanding-primer" if desired, before shooting the colour.....for nice work, I'll apply a thin coat of "Devcon Plastic Steel" epoxy putty to any pitted areas, and sand smooth, after the metal-prep etch, but before any primer....
Many delicate small parts, such as "pot-metal" (mostly zinc) carburetter castings, ignition components, or even data-plates, can be cleaned to look "as new" by a gentle blast with "walnut shell" media...."gentle" is the operative term here.....
cheers
Carla
Mike M
07-13-2004 05:13:42
I'm with the rest of the crowd. I've always said DON'T SANDBLAST a tractor unless you are going to tear it completly apart and clean it out and replace the seals.
LEJO
07-12-2004 19:59:34
I have had sandblasting done twice!! The first and the last time. Don't do it.
Keith-OR
07-12-2004 18:32:39
Here is FIT's website. I used the lye gravy on my 48 Allis "C", when paint, grease and caked on dirt got soft I use pressure washer to remove everthing. WORKS Extremely well. I used the elctrolysis on all the sheet metel, including front and rear wheels. Click on restoration tips on his website.....HTH....Keith Link
Mark - IN.
07-12-2004 17:45:23
Listen to the other guys. Sandblasting is ideal for sheet metal or other items that can be removed, sandblasted, cleaned, and repainted before putting back on the tractor. Don't sandblast machined surfaces (ie: manfolds, bearing races, anything else like that). Don't sandblast radiator core. Basically, can do sheet metal, bare rims or the likes of, after removed from your tractor. I'm drawing a blank, but there are other mediums that work just as well as sand for blasting, but are less harsh or abrasive than sand. And, if doing to bare metal, clean and prime same day, because rust sets in over night.
Allan in NE
07-12-2004 16:33:31
Chris,
Don't do it. Your're gonna be sorry down the road and very soon, too.
Every seal in it is gonna start leaking upon puttin her back to work.
Boat anchors, snowplow blades & highway gaurd rails seem to do well with sandblasting; tractors don't.
Just my view,
Allan
buickanddeere
07-12-2004 16:46:17
 Re: Re: Any thoughts on sandblasting? in reply to Allan in NE, 07-12-2004 16:33:31
Agreed, sandblasting an assembled tractor just drives grit past gaskets not matter how careful or taped up. Remove the sheet metal fenders and hood then sand blast them. As for the castings mix up a batch of F.I.T's lye gravey and let it diessolve off the paint and grease. Or use a 3000-4000psi 4+gph pressure washer using soap and hot water. Any paint that isn't lifted off will be on there good enough for a base.
