Tractor Talk Discussion Forum
rear wheel bearing grease ports
Tim
07-17-2004 10:42:43
I have a 1956 or 7 Massey Ferguson F-40. I am trying to grease the rear wheel bearings but cannot find a grease port. There is a counter-sunk depression on the outside wheel center but there does not appear to be an opening. Does the wheel need to be removed? Ideas?
Thanks
Tim
Dave W V
07-18-2004 05:50:45
 Re: rear wheel bearing grease ports in reply to Tim, 07-17-2004 10:42:43
Dad purchased F-40 new that was used to cut hay
with last week.Engine rebuilt 4 times,rear wheel bearings never greased or replaced.
txblu
07-20-2004 06:06:33
 Re: Re: rear wheel bearing grease ports in reply to Dave W V, 07-18-2004 05:50:45
That's what I'm looking at. I'm going to let um live or die as there is a lot involved in pulling the axle and the brakes work great.
Mark
txblu
07-18-2004 05:23:27
Just got a set of MF35 manuals. Yes they said grease rear bearings.....stupidest thing I ever heard of.
Once annually. remove all the stuff in the way and then undo the 12 bolts around the hub and pull the shaft out far enough to grease the bearing by hand.
Be careful with the shaft so as to not damage your seals.
Over the years I wonder just how many get greased..... ...do I hear none unless other work is being done?
Mark
RAB
07-18-2004 04:17:57
Does the operator manual have a lubrication section. If so, follow it.
How often should these bearings be greased? If the manual says daily or even weekly, they would never expect a farmer to remove wheels to do routine lubrication.
RAB
jake
07-19-2004 17:01:45
 Re: Re: rear wheel bearing grease ports in reply to RAB, 07-18-2004 04:17:57
FO-4 manual says clearly lube the rear axel bearings yearly.
