Tractor Talk Discussion Forum
streeing is backwards
norman lee lips
07-18-2004 08:25:55
why is it that on my 1949 case vac when i turn the sterring to the left it goes to the right and when i turn right it goes left?
Bob
07-18-2004 08:57:22
 Re: streeing is backwards in reply to norman lee lipscomb, 07-18-2004 08:25:55
I don't remember the exact details, but they used two different front axles, and the steering gears were opposite for the two applications.
Yours must be a mix of the two systems!
Jon H
07-18-2004 20:39:24
 Re: Re: streeing is backwards in reply to Bob, 07-18-2004 08:57:22
Been a long time,but I remember somthing about that the steering box arm needed to stick up for one front axle type and down for the other. Not sure if the arm must be removewd from the box to change the arm position,or if you simply remove one end of the drag link and rotate the steering wheel untill the arm is in the correct position. Check the pictures section in this site,with luck you may find a case tractor with your axle type with a view of the steering linkage position.
Jon H
07-18-2004 20:54:01
 Re: Re: Re: streeing is backwards in reply to Jon H, 07-18-2004 20:39:24
This link should steer you right er I mean correct. It looks like the sector arm needs to point up for a narrow front,down for a wide front.
