Tractor Talk Discussion Forum
2100 Leyland making weirds sounds
Super Steve
07-22-2004 12:58:28
Hi i was just out doing some discing and on the way home whenever i let of the throttle it sounded like the clutch was grinding and i could smell a bit of clutch smoke. What happened? we've only had this tractor for a month and only put about 60 hours on it. if someone could tell me whats going on it would be great. i need this tractor tomorrow morning so need info asap. thanx Steve
Tom from Ontario
07-22-2004 13:41:53
 Re: 2100 Leyland making weirds sounds in reply to Super Steve, 07-22-2004 12:58:28
Get the thing to a shop and get it apart and make sure. Another word of warning, do not treat this tractor like a 100 hp tractor. You've got 100 hp ahead of a 60 hp drive line and it will not stand sustained heavy treatment, the drive line that is. It's too bad, I've had a few Leylands and I liked them, but I was warned off this model by an old time Nuffield and Leyland guy. Get the clutch and tranny squared away, treat it like it was 65 or 70 horse and it will run for a long time. Great engine.
Good Luck.
Super Steve
07-22-2004 13:59:03
 Re: Re: 2100 Leyland making weirds sounds in reply to Tom from Ontario, 07-22-2004 13:41:53
Damn, this tractor was turned down when we bought it for fuel economy reasons. weve been pulling a 14ft disc with it. do have a general idea of what the problem is or just a heads up?
richard
07-22-2004 16:22:10
 Re: Re: Re: 2100 Leyland making weirds sounds in reply to Super Steve, 07-22-2004 13:59:03
The transmission of the tractor will stand any thing the leyland 6/98 motor can throw at it especially if it is a 10 speed,the rear axle is totally different to the leyland 4 cyinder tractors. The most likley cause is the rubber mountings at the rear of the engine have failed letting the engine move out of line with the transmission,causing failure of the splines in the clutch driven plate,providing you can get the parts on your side of the pond ok its a quick and easy fix.
Super Steve
07-22-2004 17:28:34
 Re: Re: Re: Re: 2100 Leyland making weirds sounds in reply to richard, 07-22-2004 16:22:10
How do i check this. do i have to take anything apart?
John Robinson
08-02-2004 14:22:12
 Re: Re: Re: Re: Re: 2100 Leyland making weirds sou in reply to Super Steve, 07-22-2004 17:28:34
I maybe to late, but here is a temporay fix. My family ran 2 Leyland 285's (a derated model of the 2100). I assume, you first noticed the difficulty changing gears, or hearing the gears grind every time you change gear. Our old 285 did this a lot. We use to get a jack, and take the pressure off the clutch by jacking the back end of the engine up, now is the part, I don't remember that well, as it was 12 years ago. Then there are 2 pins to replace, but I don't remember which ones. The pins that we replaced, were the pins that broke if the mounting brackets were wore. When we replaced the pins on the old 285, we would get about a month of use before the pins broke again. At the first sign of difficulty changing gears, those pins will have problably broke (Note both Leyland 285's were opened up to produce 115 engine horse power, and they used that power most of the time working heavy PTO work) On a final note, 12 years ago my family moved to Canada, and now, I am looking for a Leyland 2100 or 285 with either the 10 speed box, or the 9 speed syncro. If you know where I can find one please let me know!
Sincerely,
John Robinson
John Robinson
08-02-2004 14:24:51
 Re: Re: Re: Re: Re: 2100 Leyland making weirds sou in reply to John Robinson, 08-02-2004 14:22:12
Sorry, I forgot to post my e-mail address. My e-mail address is mikhail_kolesnikov@hotmail.com
K Chaney
09-10-2005 19:45:27
 Re: Re: Re: Re: Re: 2100 Leyland making weirds sou in reply to John Robinson, 08-02-2004 14:24:51
Mr. Robinson, my father-in-law has a Leyland 2100 for sale. It is located in North Carolina and has the 10 speed gear box. I'll e-mail you at the address in the previous posting with some of the details.
K. Chaney
