Tractor Talk Discussion Forum
Seized Motor-Question for JT
Andrew
07-24-2004 11:48:11
Thanks for the quick reply JT. But my problem is that the motor is still in the backhoe loader.
Where would I place the wrench?
The flywheel is not exposed , and I can't seem to find an access point to apply a wrench to either the flywheel bolt or any other bolts to test if I can get the motor to turn. Please advise. Thanks
mac
07-24-2004 16:39:05
 Re: Seized Motor-Question for JT in reply to Andrew, 07-24-2004 11:48:11
Pull all inj and tow it in gear. Freed a couple that way.
T_Bone
07-24-2004 14:08:16
Hi andrew,
Be careful the engine is not hydraulicly locked. Oil, diesel or anti-freeze in a cylinder(s).
Pull fuel injectors or glow plugs then try to spin the engine.
T_Bone
paul
07-24-2004 13:56:49
Generally there is a big nut on the front of the crank holding a pulley on. Sounds like you have a hyd pump up there, so need to decide what you can reach & what won't break when you turn it....
I'd look to the starter & eliminate that first, when the teeth get old they like to wear a weak spot & mash themselves together & lock up.
--->Paul
Paul Janke
07-24-2004 12:32:47
If the starter is the problem, a lot of times you need to turn the engine backwards a little bit in order to unstick the starter. Removing and replacing the starter would also get it loose, but that seems like a lot of extra work. It would, however, allow you to turn the engine with some sort of pry bar through the starter hole.
Sid
07-24-2004 12:05:41
I have had starter related problems that acted like that I would have swore the starter was OK. I am not familaiar with that machine. Can it be pulled started?
