Tractor Talk Discussion Forum
Belarus 5170 or 5150
Grant
07-26-2004 17:09:27
Went to look at the Russian Beast. It has good new tires, cab, good Allied 595 Loader with qick change - bucket, forks and round bale grapple. Starts and runs well. Had recent hydrolic work - it all responded well. They are asking 14000 CDN.
Now the bad stuff. Random oil leaks. Breaks a little soft. It will take a month to figure the shift pattern. Odd pieces of lincage diconnected. Now the real kicker- the hood says 5150 the plate at the back says 5170, built 1994. 20HP is a lot. How can I tell what it really is.
My guess is the plate on the back which is rivited to the battery cover was switched. It is a 4 cylinder.
Any thoughts, advice, warnings etc on this tractor.
Thanks, Grant
Big Jim
07-27-2004 14:44:29
 Re: Belarus 5170 or 5150 in reply to Grant, 07-26-2004 17:09:27
I have a Belarus 825 and don't have a problem getting parts. If it is a common wear part our dealer usually has the part right on the shelf. If it is not a common wear item, he will order the part and its usually there the next day (I think he orders from Milwaukee, WI). If they don't have the part in Milwaukee, it may take a couple of more days. I don't think this is any different than any of the other major dealers.
Fawteen
07-26-2004 17:47:48
Check on parts/service availability.
Grant
07-27-2004 08:42:12
 Re: Re: Belarus 5170 or 5150 in reply to Fawteen, 07-26-2004 17:47:48
I do not think parts will be a problem. There is a local guy here who sold - sells them. My neighbor who has three Belarus two masseys and a big Case Wheatland said parts come just as quik for all three.
Thanks Grant
Jim Beck
07-27-2004 08:04:48
I have a Belarus 570 and have not found repair parts a problem. There are a number of U S dealers that will provide anything you need and if you can wait a few days, you can order from Alex in the Ukrain at (belarustractors_spares@yahoo.com) at a considerable cost savings.
You can locate the U S dealers at>Link
Good>Link luck
