Tractor Talk Discussion Forum
brake linings, any way to bend........?
Ryan
07-29-2004 15:55:42
I got some brake linings made the other day and I measured my drum as being 12 inches when in fact it was more like 11.5 inches so the pads to don't want to set on my old shoes very well. I have tried bending one so far and it has broken across the holes of course, so I was wondering if anyone knew how I could get them to form a bit closer? Do I have to heat the rascals? I got a few of them and now I am stuck, any ideas? Thanks in advance.
Ryan
Vern-MI
07-30-2004 19:06:46
 Re: brake linings, any way to bend........? in reply to Ryan, 07-29-2004 15:55:42
I really am just guessing that the resin which holds he friction material together is a resin which will respond to heat. Try heating in an oven at various increasing temperatures until it becomes pliable then clamp over the shoe to develop the form.
Wayne
07-30-2004 17:28:34
Depending on what kind of lining you have as to what you can do. We've been lining bands for cranes for years and we've found that with the hard "block" lining there is no way to change it and make it smaller because thus kind of material is , for want of a better word, molded to shape. If it is a softer type solid lining or a woven lining it can usually be rolled to shape in a slip roller. Just my .02
Mike M
07-30-2004 06:52:54
Have you talked to the place that made them for you ? See what they say. You may end up getting another set,you allready need one more new one.
Where did you get linings made ? I didn't know this was an option. Is this for something very old and rare?
Ryan
08-03-2004 13:42:48
 Re: brake linings, any way to bend........? in reply to Mike M, 07-30-2004 06:52:54
They are not for anything particularly rare or old but I thought I would save some money by having them made. It cost 60.00 a set where these would run around 42.00, but I have to drill the holes in them. Here is the info I got from the MM website.
Brake Supply Co. Inc.
1300 West Lloyd Expressway
P.O. Box 447
Evansville, IN 47703-0447
Phone: 800-457-5788
Brake & Clutch lining and friction supplies. You can send them in or they will send you the material and you can line them yourself. Nice people.
Ryan
txblu
07-30-2004 05:46:35
Off the wall but would work.
Cut them into pieces and secure (rivets, glue) take to brake shop and have ground down.
Trying to take 1/4 off the corners of an existing pad is about the thickness of the pad. But if you cut them into 2 or 3 pcs per shoe, there would be much less material to arc and pads would last longer. No reason why pad has to be one piece. Some clutch discs are in multiple pieces.
Mark
Lew
07-30-2004 00:06:15
Ryan, I've been soaking some in water for a week trying to reduce the radius by about 1\2 in. with no results. thinking about heating the water up to a boil for a while. Hope someone knows the answer to your ?. Lew
Allan in NE
07-29-2004 20:24:30
Ryan,
They should be arced to the correct "roundness".
Most reputable brake shops have the abrasive drum to grind them to the proper shape.
Allan
john *.?-!.* cub owner
07-29-2004 19:44:36
If I understood correctly you got new linings made for your existing brake bands. I don't know about the ones you are using, but many of them bend easier if soaked in water for a while.
carpenter
07-29-2004 19:17:57
Ryan: Do I understand you correctly, the shoes are big? In the old days the shoes where arched to fit, that is the linings where ground, to make up for turning the drums. Also I believe the shoes should be slightly small so as to create smoother brake action. The shoe should bent to fit with more brake peddle pressure.
carpenter
