Tractor Talk Discussion Forum
8N Tractor with busted block that has been welded.
Phil Dattilo
08-03-2004 05:41:49
Should you buy a tractor with a busted block that has been welded. are you just looking for trouble. Thanks
Philip
08-03-2004 10:02:49
 Re: 8N Tractor with busted block that has been wel in reply to Phil Dattilo, 08-03-2004 05:41:49
In the early 70's, my older brother ran my Dad's 8N out of oil and threw the rod. It was quickly repaired. Now, 2004, I own the tractor, repaird block and all. No problems. By the way, the block was brazed, dont think it got into the water jacket. Philip.
Bob
08-03-2004 07:25:39
If I could be reasonably sure the engine is not leaking water internally (from another crack), and the external weld looked professionally done, and leak-free, I wouldn't have a problem buying it. There are MANY machines still out working, earning their keep, that have had the water jackets cracked and welded.
It would be a good idea to know that then engine had not been run for at least overnight, and then slightly loosen the oil drain plug, to see if any water has settled to the bottom of the oil.
rustyfarmall
08-03-2004 06:20:48
I suppose it would depend on the asking price. What condition is the rest of the tractor? If the tires, sheetmetal, etc. are good, and the price is discounted to reflect the welded block, then you may be ok. The tractor would have to be dirt cheap before I would consider it.
OliverGuy
08-03-2004 05:58:39
Looking for trouble.
TheRealRon
