Tractor Talk Discussion Forum
Farmall H Governor
Franklin Moore
08-03-2004 14:40:53
How can I get more rpm out of my 1949 Farmall H?
Les
08-03-2004 16:31:43
 Re: Farmall H Governor in reply to Franklin Moore, 08-03-2004 14:40:53
With the engine stopped, take off the governor housing cover and turn the governor screw until it just touchs its stop. Place the hand lever in full speed position and turn the high idle speed screw until it just touchs its stop. Finally, start the engine and place the hand lever in full speed position. Then turn the high idle speed as required. Turning the screw in reduces speed and turning it out increases speed. The stock setting is 1650 RPM under load, 1815 no load.
