MM BF Engine Parts
Jim Ryan
04-15-1999 08:37:08
I am restoring a '51 BF with a Hercules engine. Where can I get two valves? I may also need rings and bearings.
Greg Surat
01-26-2004 22:29:10
 Re: MM BF Engine Parts in reply to Jim Ryan, 04-15-1999 08:37:08
If you are the Jim Ryan that graduated from UOP in Stockton, Ca and worked at Yonada Japanese resturant please contact me ASAP. This is urgent please contact me ASAP.
Regards,
Greg
209-712-6218 cell
650-878-8505
Jack in NB
04-15-1999 14:38:00
Hi Jim -
Some sources, gleaned from the net over the past 2 years:
M&M surplus sales, Bronx NY 718 821-9026
Dan Carpenter, Dansville MI hobsickle@aol.com
Landis Zimmerman, Euphrates PA 717 738-2573
If you can find an engine model number it would help.
IXB-3? IXK-3? number plate on the right side, held on by rivets - often goes missing. May be stamped on the oil dipstick too.
Similar engines were used in the Generals, and HG/OC-3 Cletracs.
Jim
04-16-1999 08:16:46
 Re: Re: MM BF Engine Parts in reply to Jack in NB, 04-15-1999 14:38:00
I found valves, rings and gasket set. I need bearings 2M under. The engine model number is IXB3SL 3 1/4X4.
