Tractor Talk Discussion Forum
Purging hydaulic system
Don E. Foster
08-04-2004 20:42:36
I have just put my 3ph back on and will soon start it up. How do I go about purging the air out of the system. I assume I should have the cylinders compressed and loosen the hose connection a hair to let the air out. Is this correct? I have a '43 Farmall H that had an add on 3ph that is a dandy, but heavy. Thanks
TimFL
08-05-2004 08:08:31
 Re: Purging hydaulic system in reply to Don E. Foster, 08-04-2004 20:42:36
Just make sure you check the tank after you purge the air as it will likely be low from filling the cylinder.
My $.02
G-MAN
08-05-2004 07:41:02
The other two gentlemen have it right. Cracking lines and the like is nothing more than a good way to make a mess and possibly injure yourself. Fluid injection injuries are not something you want.
KURT (mi)
08-05-2004 01:55:04
Once you start the system, and move the cylinders. the air will push its way out into the oil holding tank and will not be an issue, it is not like bleeding brakes on a car. (at least this is the way it is on industrial machines)
rustyfarmall
08-05-2004 04:41:51
 Re: Purging hydaulic system in reply to KURT (mi), 08-05-2004 01:55:04
Yes, this is the way it is done, make sure all connections are tight, and then run the cylinder (or cylinders) in and out several times. The air will escape into the reservoir.
