Tractor Talk Discussion Forum
Woods mower swap...
Stan(PA)
08-05-2004 05:14:38
Anybody know what I'd need to change to swap a mower deck? The Woods L-59 deck is currently on a 1947 Allis Chalmers B. I want to buy it, and mount it on a 1946 Farmall A. Does this require major rework? I'm hoping one of you guys have done it before.
Charles Jackson
08-05-2004 09:07:27
 Re: Woods mower swap... in reply to Stan(PA), 08-05-2004 05:14:38
I think you will need only two things: the
assembly that mounts between the final drives
is different. (I have one for the A Farmall
for $75.) and the drive pulley off the belt
pulley shaft is different. I might have one of
those, I am not sure.
Stan(PA)
08-05-2004 09:59:42
 Re: Woods mower swap... in reply to Charles Jackson, 08-05-2004 09:07:27
Charles, I have a belt pulley on the Farmall, as there is an International C3 mower on it now. I assume this pulley would work. Where are you located? The assembly would probably be too heavy to ship reasonably. Can the Allis assembly be cut and welded, or are the mounting points also different? Would be easiest with your assembly, depending on location. Thanks....Stan
