Tractor Talk Discussion Forum
Airless paint sprayer
stan
08-07-2004 21:41:39
Has anyone had any experience with the Wagner airless paint sprayer called (Paint Crew) it holds 2 gal.of paint at a time. I know for around 200.00 I can't start a painting business, but for painting a tractor, or house will it do the job?
Steve W (NY)
08-09-2004 07:38:43
 Re: Airless paint sprayer in reply to stan, 08-07-2004 21:41:39
With practie they work good for the frame....just the cast parts. For sheet metal, they just shoot too much paint and are prone to runs. A good cheap touch up gun (I paid 19 bucks at BJ's) and a small water trap (10 bucks at Harboutr freight) and a Air compressor are all you need to do a nice job that will be better than factory paint. If you are looking to make your tractor shine like a new Corvette (that would be just silly), then you need more cash.
Take Care
Steve
Mark - IN.
08-09-2004 06:04:58
My two experiences Stan, no joke. First Wagner sprayer was the $190.00 job, had two 5' hoses (one under pressure, one return into the bucket). Was selling a house, didn't feel like rolling. The supplied hoses are about 5' long - get yourself much, much longer ones from the hardware, and put weights on them. The somewhat ridged 5' return one came out of my 5 gallon paint bucket and I had paint all over the floor before I noticed it. Was a big mess. BIG MESS. I tossed it the same day I bought it. Then years later painting a metal shed with lots of ridges that the brush and roller weren't doing as well on. Hmm? Try another Wagner? I bought the $50 cheaper model without hoses. Did not like oil based paint (Rustolium) and clogged until I had the paint thinner than water. Tossed that one too, same day bought it. Now, I just use a brush and roller, or a compressor that I have for my compressor. I'd have kicked both Wagners, but didn't want to break a toe or foot. Good luck.
jim
08-08-2004 21:28:50
Airless guns work good for buildings, steel or wood, but I wouldn't try to paint anything fancy like a tractor. Houses would be a tossup. For big open areas it would be ok, but around windows ,shutters, and trim you would really have to watch out for overspray. Keep vehicles away that overspray can drift. I don't know about the new ones but the older ones will spray latex or oil. They would also spray that alum. asphalt roof spray for steel roofs.
Jason(PA)
08-08-2004 18:03:14
They are fine if you are painting something that is wood,like a deck or fence,but they are not good for smooth metal serfaces. It looked too splatered when I tryed to paint metal garage doors with one. Plus they make alot of noise and it gets on your nerves. You can buy a pretty cheap regular paint gun that runs off of a compresser that would work 10 times better.
Chris Brown
08-08-2004 09:41:58
Most of those airless guns say for latex paint only. I'd check it out before I bought one.
