Tractor Talk Discussion Forum
8 volt Battery
Northern ca.
08-11-2004 07:16:07
can someone tell me how to charge An 8 Volt battery. Thanks in Advance
Delbert
08-11-2004 19:01:54
 Re: 8 volt Battery in reply to Northern ca., 08-11-2004 07:16:07
Use your 6 volt charger just like you would a 6 volt battery. Charge mine every so often has worked for year that way. The reason i have to charge my 8 volt is because of to many short runs at idle speed on tractor the old gen doesn,t keep up. Yes just charge on 6 volt side and it will do fine.
TheRealRon
08-11-2004 07:54:00
Buy an 8 volt battery charger.
Bob
08-11-2004 08:49:54
 Re: 8 volt Battery in reply to TheRealRon, 08-11-2004 07:54:00
Or use a 12 Volt charger with a headlamp bulb in series with one of the leads. Monitor the voltage at the battery, when it gets up around 9.9 Volts, the 8 Volt battery is charged up.
