Tractor Talk Discussion Forum
Hard to start FarmallB
Abdon S. Cejka
08-14-2004 07:17:07
I have to pull choke out and keep it all way out to keep tractor running. all parts electrical and fuel are new and carburator is rebuilt. Could this be bad vacume leak or a governor problem?
Abdon
08-15-2004 18:34:52
 Re: Hard to start FarmallB in reply to Abdon S. Cejka, 08-14-2004 07:17:07
Hi. Thanks for the advice on the hard to start farmall"B" and will try soon and let you know how it works.
Coloken
08-14-2004 13:34:36
A completly plugged up air cleaner can do this too. Once had a LA that would only run at idle with choke out. Was a bird nest.
TheRealRon
08-14-2004 07:41:18
Vacuum leak or restricted fuel flow. Easy enough to test... with engine running at idle spray some carb/choke cleaner around the carb/manifold mating surface and then each of the intake posts at the head... any change in speed/sound means you have a leak.
Carb may be way too lean, tank not venting (gas cap), float level too low, etc.
