Tractor Talk Discussion Forum
Farmall Super A
Hal
08-15-2004 17:54:25
I have a 1948 Super A which I left sitting up for
a couple months and the clutch is stuck and will not release. I tried pulling it with the pedal pressed in but that didn't do the job.
I can see that there is about 1 inch of free play in the rod.
What is the best way to make the clutch release again?
Thanks in advance for help!.....Hal
TimFL
08-16-2004 06:53:22
 Re: Farmall Super A in reply to Hal, 08-15-2004 17:54:25
You didn't say if its running or not but the only way I have found to break my Farmall 140 free is to drive it in high gear. I crank it in 2nd work it up to 4th and ususally with in a 1/4 mile its free. Sometimes it works to put it in gear and pull it with the engine off and depressing the pedal.
My$.02
john *.?-!.* cub owner
08-15-2004 19:28:09
Hal, try putting a block behind the clutch pedal to hold it down and spraying it with brake-kleen a few times.
