Tractor Talk Discussion Forum
new hay field
river bottom fa
08-20-2004 20:13:43
I PLANTED A NEW HAY FIELD IN THE SPRING I DRILLED ORCHARD GRASS ANT TIMOTHY IN MARCH AND THE WEEDS TOOK OVERIN MAY I WAS WANDERING HOW YOU GUYS PLANT A NEW HAY FIELD
kyhayman
08-21-2004 19:36:07
 Re: new hay field in reply to river bottom farmer, 08-20-2004 20:13:43
May depend somewhat on where you are. I certainly agree with the other posts about the problems with annual weeds in a new seeding. I budget to get 0 harvestable hay the first year off a new seeding of anything. With that said timothy particularly is almost never seeded here in the spring. As we are outside the recommended area it just doesnt do well most years unless fall seeded. Orchardgrass is also much better suited to fall planting here. They both spread too slowly to compete with the spring and summer weeds, may experience a total stand failure (been there more than once).
Allan in NE
08-21-2004 06:45:20
RB,
I'm with the other guys.
It is just like when you plant a new lawn. The first thing you see is a nice crop of weeds.
Mow 'em off of there and that grass will soon get a foot hold and will then choke out the weeds.
Allan
paul
08-21-2004 03:40:05
I'm with Hugh, mow it for a while, grass takes a while to show up with any strength.
--->Paul
Hugh MacKay
08-21-2004 02:46:42
Not a lot wrong with what you did, if you have a good catch of grass starting just keep the weeds mowed off before they go to seed. Every weed you allow to go to seed is 1,000 new weeds for next year. I am assuming most of your weeds are annuals, whereas the grasses you seeded are perennial. The old mower is still the most economical way to kill annual weeds in a perennial crop.
If your weeds are perennials, then more drastic measures will be required.
