Tractor Talk Discussion Forum
Case 440 foamy hydraulic oil
DaveMarshall
08-21-2004 16:23:01
I bought a Case 440 the other day. The 3 point hitch wouldn't lift the tiller that was attached and the hyd. pump sounded awful. I thought there might be air in the lines so I cracked open a fitting. Some air "burped" out, but the oil is very foamy even after several hours. Any help would be appreciated. Also , does the trasmission and the hyd.system share the same fluid?
TimFL
08-21-2004 21:09:49
 Re: Case 440 foamy hydraulic oil in reply to DaveMarshall, 08-21-2004 16:23:01
Could be the oil itself. Have seen certain oils that have a bad tendency for foam.
My$.02
