Tractor Talk Discussion Forum
Cutting cab glass
Todd in Indiana
08-21-2004 19:45:34
I am needing a piece of glass for the cab on my White 2-150. Would it be possible to cut it out of a larger piece of glass from the cab of another tractor?
720Deere
08-22-2004 15:29:01
 Re: Cutting cab glass in reply to Todd in Indiana, 08-21-2004 19:45:34
Any good windshield shop should be able to make their own pattern and cut a glass for that cab. All the glass for our construction equipment is custom cut. Windshielf for a Cat loader is usually around $250 cut and installed.
Paul Janke
08-21-2004 21:04:00
If it is the kind with the plastic in between two layers of glass, score both sides of the glass. I"ve been told to soak a string with lighter fluid, lay it along the score, and light it on fire. I always just bent it enough to cut the plastic with a razor blade after I broke the glass along the score lines. I didn"t have money for new glass for my old pickup while in high school.
ErnieD
08-21-2004 19:49:26
Nope
If it is tempered, it is impossible to cut w/o shattering.
If is bonded safety glass, you can't cut/snap through the butacite plastic.
