Tractor Talk Discussion Forum
implement suggestion
diggerdog
08-22-2004 19:49:40
I bought a 75 horse New Holland tractor to play around with on a timber tract I bought. Being new to tractors, I have only bought a 5 ft Rino mower to mow in between 25 year old planted pines. The dealer said it will mow anything the tractor will run over, but it seems to violent on the mower. I am wondering if there is a bulldozer-like blade you can put on the front of a tractor to push over unwanted trees. None would be bigger than my neck, but want to save the mower for forearm (small) sized trees and scrub oaks and use a blade for light road-building-land clearing. New to this world, so any advice would be appreciated.
TheRealRon
08-23-2004 06:39:45
 Re: implement suggestion in reply to diggerdog, 08-22-2004 19:49:40
I use my 7' Rhino for the same purpose. It has a clutch in it so you really can't hurt it or the PTO. But you should follow the rules in the Owner's Manual... 2" diameter trees are all you can cut safely.
Further, you really don't want to be pushing trees over with a tractor:
First, you have tractor, not a dozer. Besides, you really should be backing the cutter into heavy trees. It's much easier and safer and you get better results.
Second, logging stubble is very sharp. You'll want some www.ultraseal.com in your tires. www.gemplers.com sells it. Fixing flats in the forest isn't my idea of a good time. Keeping the rears very soft, just "up", is the best way to go.
Third, forgive me for being blunt but you bought the wrong size cutter. The cutter should be about the same width as the rears. A 7' or 8' cutter is just right for the size tractor you have. The reason is that as you back into the trees, you must cut a path wide enough for the tractor.
If you want to build roads (I do that too), get a 3 pt box blade and a loader. If you want to clear land, find a neighbor with a dozer.
Leland
08-23-2004 03:23:41
What the dealer should have told you was 3-4 in trees anything bigger than that you need a heavier built chopper.. Like what power companys use on right a ways , and since your new at this you will live longer if you walk area first to check for dangerous objects
paul
08-22-2004 23:17:46
Farm tractors are best for farming dirt. You are getting into pretty specialized tree handling equipment. Bigger than a forearm, and I guess I would look to specialized forestry vehicles for doing much of any of this type of work.
--->Paul
