Tractor Talk Discussion Forum
skipping johndeere
johndeereman
08-23-2004 09:30:53
i have a 1943 johndeere b sounds real good under a load but when just putting around it misses once and a while went to our local tractor show put it on the bakers fan tuned it up amazed everybody at the power it had for a stock jd b but i only got one suggestion as to why it would miss once and a while that was the camshaft bearings where bad going to change them think they are original but not sure if it is the problem works real good under load any other suggestions?
Rockin' Farmer
08-24-2004 07:35:36
 Re: skipping johndeere in reply to johndeereman, 08-23-2004 09:30:53
johndeereman,
Bob and Allan are right. It"s supposed to sound that way! Don"t you love it. Only better sound is when that B is under a heavy load!
Enjoy,
Rockin" Farmer
Dick2
08-23-2004 11:57:41
We had problems like that with our G; it was usually that the bushings were worn on the throttle shaft in the carburetor, or there was a leak on the intake gasket.
benjb in NE
08-23-2004 10:16:04
Check the plugs.... I have a 520 that likes to foul the left hand plug. Gradually starts missing more and more (especially at idle) until I pull it out for a cleaning or replacement.
Allan in NE
08-23-2004 09:43:07
Hi JDM,
Bob has hit the nail right on the head. That tractor is supposed to sound like that.
Be glad it does, you have a unique tractor and many of us really like the way those old gals sound when they idle. :>)
The newer ones sound sweet too, but there is just something about that old "skip one once in awhile" sound that is nice to hear.
Believe me, people envy you and your old B.
Regards,
Allan
Mike M
08-23-2004 09:41:09
John Deere A's have trouble with cam bearings not the B's .The B's don't really have bearings the cam runs in cast housings that have oil pressure feed to them.
What you have described sounds like a normal John Deere 2 cyl. with a single induction carb. at an idle the 2nd cyl. doesn't get a good fuel mixture so they don't run smooth until a load is applied. The models starting in 1953 like the model 50 and 60 have dual induction carbs. and they run much smoother.
Bob
08-23-2004 09:36:31
The are called "poppin Johnnies" for a reason! Due to the uneven firing arrangement between the 2 cylinders, the RH cylinder tends to get a leaner gasoline mixture, especially at idle or light load, and some misfire is normal.
On the numbered series of Deere 2 cylinders, this issue was addressed by going to a 2 barrel carburetor and manifold, so each cylinder got the correct mixture.
Harley1983
08-23-2004 14:23:57
 Re: skipping johndeere in reply to Bob, 08-23-2004 09:36:31
Boy that sure eases my mind. I sold an older B the other day on EBAY, and me being a farmall man, I spent over a week looking for the other two cylinders. I think if I could have found them, that tractor would have sounded about right. As it was, I about gave it away cause I told the man who bought it that I just couldn"t get it to run right. Silly me. Harley
