Tractor Talk Discussion Forum
diesel that wont stay runing
sal
08-24-2004 17:39:06
hi i have a randsom 6000 with a kaboto diesel. great machine, but now it will start and run untill it warms up then it just shuts down. you can restart it but it will shut down after a few seconds. fuel system all looks right, tep sensors are all working fine and oil sensors are also fine.
thanks for your help
JDknut
08-25-2004 04:20:31
 Re: diesel that wont stay runing in reply to sal, 08-24-2004 17:39:06
Sounds like it might be a filter issue.
UFO Man
08-24-2004 17:55:14
Sal, there are three things that a diesel needs to run: Air, Fuel and Compression.
Since it is running well for a few minutes, let's assume that there is compression and that is not changing.
That leaves fuel and air. My guess is that something is shutting off the fuel flow.
But check the air filter first, it's the easiest and cheapest to fix. Make sure that the engine will run on start up without the filter. If it continues on running, the problem is found and all you have to do is replace the filter. They have been known to collapse and clog the intake.
If it is not the air, then the fuel system is sucking air, clogged with dirt or something is in the tank that is restricting the flow of fuel.
Changing the filter and purging the fuel lines is a normal maintenance chore. It won't hurt to do that anyway. While you are at it, drain the tank and have a look inside. If the tank is clean, get the fuel lines air tight, purged and start her up. If the fuel tank has crud in it, especially large chunks, take off the tank and clean it.
Good luck and keep us posted, we like to hear success stories.
UFO Man
Bob/Ont
08-24-2004 18:06:40
 Re: diesel that wont stay runing in reply to UFO Man, 08-24-2004 17:55:14
Sal,First check the fuel tank vent. It might be clogged and causing a vacume. After you leave it for a time air gets back into the tank and you get some running time before it vacumes again. When it stops take off the cap and listen for a hiss. Then restart and see what happens. Also if it has a fuel return line on it, make sure it's not clogged or pinched off, it's to bleed off any air the pump picks up.
Later Bob
