Tractor Talk Discussion Forum
Best belt drive governer??? Need one
Andy2
08-24-2004 21:23:53
I need a belt drive governer for a tractor I'm putting together. I'v heard some don't work well at all RPMS. I'm after one that will respond well and hold at low to mid-range as well as high rpms,(2500) I need a source to buy one as well. thanks, Andy
Bob M
08-26-2004 04:52:48
 Re: Best belt drive governer??? Need one in reply to Andy2, 08-24-2004 21:23:53
I've had good luck with the Pierce "universal pulley driven governor". Provides stable control over the entire RPM range, and is easy to mount and adjust.
Ben in KY
08-25-2004 05:41:33
I believe Valu "dash" bilt "dot" com has those.
Old walk behind Gravely tractors had them, might be cheaper to buy an old Gravely than one new, they are not cheap.
Jon H
08-25-2004 06:32:52
 Re: Best belt drive governer??? Need one in reply to Ben in KY, 08-25-2004 05:41:33
Most of the Gas engine farm equipment (swathers,combines etc) with Ford GM or Chrysler ind engines used belt drive governors(usually Roof or Hoof). Most were used in a limiting speed instead of a true variable speed application,so do not control well at low to mid speed unliss you use a high ratio in the belt drive(50-100% overdrive. Most are a two weight governor,but the four weight models work better at low rpm. You can tell the number of weights in a unit by turning the shaft (shaft horizontal)slowly with the governor throttle lever backed away from the weights. as the shaft rotates,the weights will click as they fall. Two clicks per turn=two weight. Some two weight models have the carrier for four weights which can be added from another parts governor. I think someone posted earlier that the Northern surplus catalog had new surplus belt drive Hoff governors for $20-30.
