Tractor Talk Discussion Forum
Bolens
Rusty2
08-27-2004 11:48:40
I have a Bolens with several different model# on it and I need to know what I have and what proper type of battery I have to put in it. The battery that is in it now heats up and boils over and I am afraid it will exploid. Can anyone out there help. The numbers on the tractor are: on the decals under the hood TX2140 and TX2160. On the Frame on the left front side is TX1410-006116.
Would appericate any help that I can get, also what year is it if you know.
Thanks
seth finney
08-27-2004 11:57:01
 Re: Bolens in reply to Rusty2, 08-27-2004 11:48:40
try a 12 volt or higher i think
Jonathan
08-27-2004 11:55:59
Can't help you with the model, but it must take a regular 12 volt lawn tractor battery. If your unsure take the old battery into the parts store with you and tell them you need a replacement. Sounds like maybe your charging syestem is malfuntioning and putting too much juice in your battery to case it to heat up and run over.
