Tractor Talk Discussion Forum
Loaded tires
Jim Nauert
08-27-2004 18:17:34
Would anybody know a easy way a guy could load his own tires to save a few bucks. Or would i be better off to hire it done i think i can get the calcium for free.
Leland
08-31-2004 18:46:04
 Re: Loaded tires in reply to Jim Nauert, 08-27-2004 18:17:34
Jim in the long run it will be cheaper to just drive to nearest tire shop. After you buy all the dodads and calicem to put in them, them drive to nearest car wash and blast rims good to get that metal eating stuff off.Also how old are your tubes you may be money ahead to replace them also to prevent leaks and rim damage. I"ve been on a few service calls to fix someelses mess and the boss charged them dear!
buickdeere
08-28-2004 19:21:21
Just out of curiosity. What kind of tractor, how is it set up and what all will it be used for? There are occassions where liquid rear ballast is required but..... ..... ...
Jim Nauert
08-29-2004 04:19:38
 Re: Loaded tires in reply to buickdeere, 08-28-2004 19:21:21
It's a john deere 420W with 13/6 28 rubber with back blade going to use it this winter to plow snow. We live on a hillside.
buickanddeere
08-31-2004 09:16:35
 Re: Loaded tires in reply to Jim Nauert, 08-29-2004 04:19:38
It's not a real beefy rear end in there. Almost all rubber tractor tires slip on ice/snow no matter the weight. Chains dig in and grip. How about a very narrow snow blower and no chains. If the blower auger is full the tractor tires will spin .This reduces auger bearing, pto and tractor stress.
shade tree
08-28-2004 05:21:08
A 5 gal bucket with a hose attached to the valve stem sitting higher than the tire and you can put what ever you want in the tire.
shade tree
08-28-2004 05:25:30
 Re: Loaded tires in reply to shade tree, 08-28-2004 05:21:08
The raidator shops will give you all the used antifreeze you want if you bring your own barrels.
TheRealRon
08-28-2004 03:35:23
www.gemplers.com sells the tools you need and has instructions on their site on exactly how to fill the tires.
john in la
08-27-2004 20:17:33
Do not know about calcium because we use only water in our area but if you could get it into a piece of garden hose by say a funnel you could use this.
It is a water/air adapter model 221 made by Rema that I bought at our local tractor dealer. It has 2 adapters to fit both regular and large valve stems.
Hope this helps
John
third party image
John *.?-!.* cub owner
08-27-2004 19:03:16
Many auto parts, farm supply, adn tire stores sell the adapters for filling your own tires. I've never used one, so I don't know how well htey work, but you will need tubes with valve stems designed for fluid. They have a bigger stem that a second smaller valve stem assembly goes on with a nut.
