Tractor Talk Discussion Forum
Has CocaCola lost its knack for breaking free an e
JR#1
08-28-2004 22:59:19
Hi guys. i have noticed that the old coca cola in a stuck engine trick doesnt work so well anymore? maybe i got a light batch or something. are any of yall still using it, and are any of yall havin any luck with it? i just wondered if maybe they have changed the ingredients slightly or something. or is it just me? any ideas out there? what is best to use these days? thanks in advance!
if
08-29-2004 14:59:12
 Re: Has CocaCola lost its knack for breaking free in reply to JR#1, 08-28-2004 22:59:19
you put spill some Cokecola on the kitchen counter and leave overnite then you have a glue-like substance. Don't think that is going to free your engine.
Bob
08-29-2004 12:58:49
 Does your chewing gum lose in reply to JR#1, 08-28-2004 22:59:19
it's flavor on the bedpost overnight?
(Sorry, that just popped into my mind when I saw the Coca-Cola comment!)
Does anyone remember that goofy song?
Does Your Spearmint
08-29-2004 19:24:25
 Re: Does your chewing gum lose in reply to Bob, 08-29-2004 12:58:49
lose it's flavor on the bedpost overnight?
If your mother says don't chew it
do your swallow it in spite?
Can you catch it on your tonsils,
can you heave it left and right?
Does your spearmint lose it's flavor
Mike (WA)
08-30-2004 08:41:11
 Re: Does your chewing gum lose in reply to Does Your Spearmint, 08-29-2004 19:24:25
On the beddd-possst oooo-verrr. . . (a dollar is a dollar and a dime is a dime, I"d sing another chorus but I haven"t got the time)
On the bed-post over-niiiiight!
Stan(PA)
08-29-2004 17:24:52
Does your bubblegum lose it"s flavor On the bedpost overnight? If your mother say"s don"t chew it, Do you swallow it in spite?
Nah, I don"t remember that stupid song....
that
08-29-2004 14:51:51
was chewing gum
deadeye
08-29-2004 12:29:27
Whaatever stuck it will unstick it. When it runs out of something is when it sticks. If it had water on it, when it dried off the water, it stuck. OK!!! SOAK IT IN WATER AND PUT A LITTLE PRESSURE ON IT AT THE SAME TIME. The difference in WD40, Blaster, and water is drying time...JB..deadeye
curt
08-29-2004 10:32:47
sea foam "deep creep" works good on rusted bolts and such, try it
Jonathan
08-29-2004 09:25:28
Never tried coke, but usually use a concoction of penetrating fluid and diesel fuel to break free an engine.
MarkB_MI
08-29-2004 08:43:37
The magic ingredient in Coke is phosphoric acid. You might try using something a little stronger, like "Ospho" (available in paint stores).
Fact is, not all stuck engines are the same. Just because you got one to break loose with a little coke doesn't mean this will work on the next one.
John M
08-29-2004 05:08:25
Never had Coke work,never had PB Blaster work for anything better than I would use WD40 on,vinager I have never tried,I have used KROIL with some success.Best thing I have found to break loose a good stuck engine,SLEDGE HAMMER AND BOARD!Although once,while working on my Super MD, I accidentally spiulled some baking soda into one of the cyliders,it just happen to have some antifreeze in it and a couple days went by before I noticed it.When I cleaned it out,the rust had been disolved considerably.I didnt get the engine broke loose like that but I may try it on day on purpose.
Alberta Mike
08-29-2004 15:01:10
 Re: Has CocaCola lost its knack for breaking free in reply to John M, 08-29-2004 05:08:25
I agree 100% John with your response. I have never had much success or faith in any of the so-called penetrating oils and their ability to loosen up a stuck engine. GENTLE hammering and a board with a good dose of patience and the magic ingredient ... HEAT. I don't think the oil is totally useless, probably only 95% useless.
Bowlegs
08-29-2004 04:57:46
Use vingear is a mild acid and works good just fill the cylinders and let set top off as needed. 2 weeks to a month rings and all are free. It really does work best I have tried. Uncle used it on a 340 farmall stuck for 5 years and the tractor runs good and doesnt use oil.
TheRealRon
08-29-2004 03:28:49
PB Blaster, any auto parts store.
rustyfarmall
08-29-2004 04:50:43
 Re: Has CocaCola lost its knack for breaking free in reply to TheRealRon, 08-29-2004 03:28:49
P.B. blaster DID NOT work for me. Read the label on that stuff, it"s not much different from any other penetrating oil.
Jim Nauert
08-29-2004 04:30:35
I will have to agree that PB blaster will work. I have not had better luck with any other brand of penatrating oil including some comercial grades we have at work.
