Tractor Talk Discussion Forum
OT- 99 Chevy Blazer
Casey in Ky
08-29-2004 12:59:37
Wifes got a 98 Chevy Blazer. The combination flasher(turn signal clicker) stays on most of the time. Just kinda comes and goes except for when the brake lights are on, and that stops it. I've replaced the flasher and that didn't fix it. Everything works fine, all the turn signals and lights, just keeps clicking all the time. Any suggestions as to a fix?? Thanks
Casey
TheRealRon
08-29-2004 16:04:50
 Re: OT- 99 Chevy Blazer in reply to Casey in Ky, 08-29-2004 12:59:37
The switch is bad or there is a bad ground. Don't even think of going inside the steering column unless you have a service manual or you just might set off your airbag.
Auto electric shops are usually a better choice than a dealer for these things.
GMorrison
08-29-2004 13:51:02
Sounds like a turn signal switch. Stepping on the brake by-passes the switch. Make sure that the switch is actually turning off. Replacement will require removal of the steering wheel.
Gregg
