Tractor Talk Discussion Forum
Hauling Ford 8N with small pickup
Doug in Minneso
09-01-2004 18:51:45
Can I haul my Ford 8N (2,600 lbs) across the country with my Nissan 4x4 pickup? I have a single axle (rated at 3,500 lbs) trailer that weighs 800 lbs. The Gross Vehicle Weight Rating for my truck is 5,100 lbs and the Gross Combined Weight Rating is 7,700 lbs. The Maximum Tongue Weight is 350 lbs.
OGGIE
09-04-2004 19:26:33
 Re: Hauling Ford 8N with small pickup in reply to Doug in Minnesota, 09-01-2004 18:51:45
fIRST TIME IN THIS FORUM , VERY INTERESTING.
FIRST LET ME SAY THIS WOULD BE A VERY FOOLISH THING TO DO NEVER MIND IF IT'S LEGAL OR NOT.
NEXT THING A NISSAN PICKUP IS ABOUT THE MOST ANEMIC THING I'VE EVER DRIVEN V6 OR 4 CYL. AND
IF YOU GET INTO HIGH ALTITUDE YOU WILL THINK IT
IS RUNNING AT HALF POWER . I WAS A TECHNICIAN AT A NISSAN DEALER IN LARAMIE WY. 7200 ft.AND PEOPLE
PASSING THROUGH WITH TRUCKS AND PATHFINDERS PULLING TRAILERS WOULD COME IN ALL THE TIME SAYING THEY HAD NO POWER.
ALSO WITH THE SINGLE AXLE YOU ARE GOING TO WRECK SOMEWHERE ALONG THE WAY I WOULD BET ON IT AND I WOULDN'T BET AN ANT COULDN'T EAT A BALE OF HAY.
Davis In SC
09-02-2004 19:10:30
This has been an interesting discussion !!! One more opinion I would like to offer. My truck & gooseneck trailer are only a few years old, excellent shape, good tires, all lights work, etc. I am under the assumption that , in some jurisdictions, I need a CDL since the ID plate says trailer is rated at 12,000..... If I were hauling the same load wqith a half-ton truck pulling a light , ragged trailer, I am exempt. My question is ... which one is a bigger hazard to other motorists????? Also, a question ... If trailer is rated at 12,000 (Gooseneck) does that mean 12 K on the tandem wheels, or wheels + tongue weight in the eyes of the weight police ???
T_Bone
09-02-2004 20:06:52
 Re: Hauling Ford 8N with small pickup in reply to Davis In SC, 09-02-2004 19:10:30
Hi Davis,
It would be 12k on the scales minus pin weight attached to the TV and how most mfg"s rate there trailers.
From what I"ve seen the tire capicity is the weakest link on singles and axles on duals. It would depend on the mfg tho.
Tell me about it. Fords F150 is rated to haul more payload weight than a F250 that has larger brakes, heavier frame, larger differential(s), heavier tires, more lug nuts and more spring weight according to Ford. Just doesn"t make sence at all! Stickly marketing!
T_Bone
thurlow
09-02-2004 12:51:00
I always truly love posts like your's that start out, "Can I..... ..." It brings what I term "the hand wringers" out in force.....as well as the well thought-out, well intentioned replies. Been hauling "stuff" about 50 years; would I do what you're suggesting..... .NO WAY, but to each his own. Not flaming you..... I do like these posts.....
Davis In SC
09-02-2004 10:20:59
Here in SC, the Transport Police WILL pull you over for suspected weight violations. & I am glad they do..... Word is out that they are targeting individuals, not just commercial haulers. 12 ton tag for my dually is $308.00 every 2 years, but I bet that is a lot cheaper than the fine if I were caught being several tons over my tag weight. I see some real dangerous hauling , such as a 3/4 ton Ford pulling an AIR-BRAKED trailer hauling a 450 JD Loader.... I got out of his way !!!!! ! He should have been stopped & fined. I wonder how long the truck brake took to stop him ???? Regards Davis
T_Bone
09-02-2004 09:48:04
Hi Doug,
Lets run some numbers:
8n= 3000lbs WET, 2717lb dry shipping weight.
trailer= 800lbs, scaled weight or SWAG (scientific wild @ss guess)?
trailer tire capicity? unkown
No trailer brakes
3800#GVW total guessamint, Better than a SWAG as we know the tractor weight. Were shot down here as were over GVWR of the trailer.
TW= 10 To 15% of GVW, 12%TW = 456lbs tongue weight. Your dead in the water here as your hitching is only rated 350lbs. New class III reciever and ball mount required. A class III is rated upto 5000GVWR, Class IV is 10000GVWR. As stated in below posts, consider WD hitching.
Most States require trailer brakes for a 1500lbs or more GVWR and for a good reason. How are you going to stop trailer sway if you don"t have trailer brakes? Anytime trailer sway starts your first reaction would be to manualy apply trailer brakes, let off fuel pedal, then lightly apply TV (tow vechile) brakes. Never try to correct sway with steering or you will loose total control! My State (AZ) is 3000lbs GVW single axle and 6000lbs for a additional brake axle. Again were shot in our foot.
Your trailer is rated 3500 GVWR. I would suspect that would be a flatdeck rating, meaning the 2700lb load (3500-800=2700 allowed load weight) is distributed over the entire deck surface, NOT like hauling a 4 wheel vechile that distributes load weight in FOUR places on the deck. Another strike.
A "car" trailer as it"s called, has wheel rails (beams on heavier rated trailers) that can support the four bearing points of the vechile load over the entire frame of the trailer.
Thats why we have vechile load rated trailers and cargo load rated trailers.
A good vechile rated trailer with a 7000GVWR, tandum electric brake axles, is going for about $1400 new (you can"t build it this cheap yourself).
Sell your cargo trailer for $300 and buy a trailer and hitching that can safely haul your tractor across country.
T_Bone
Correction Adam Paul
09-02-2004 07:58:32
 Correction Re: Hauling Ford 8N with small pickup in reply to Doug in Minnesota, 09-01-2004 18:51:45
I had grabbed (from the equation) the wrong number when I posted the tongue weight. The tongue weight should be 408 lbs.
2600+800=3400. 12% of 3400=408
Time for a new hitch…
Adam Paul
Indydirtfarmer
09-02-2004 07:24:24
DISCLAIMER: I"m only commenting on what someone else did. I"m not advocating doing the same....
About 6 months ago, one of my nephews hauled a Ferguson TO-30 about 250 miles on a "golf cart trailer" with a GVW rating of 3500. He pulled it with a Toyota Camry (CAR). He was running at 80 MPH on the interstate. Miraculously, he"s still alive. I"d recomend keeping the speeds to a minimum. (55 or less) With a single axle trailer, you blow ONE tire, and it"s disaster time. When I sell a tractor, and the buyer wants it hauled, I recomend they call an auto wrecker service. Roll-backs are just the ticket to haul a small tractor. John
Steve (Magnolia, TX)
09-02-2004 07:15:41
I"d be more concerned about the trailer than the truck. Personally, I wouldn"t tow a tractor (any bigger than a lawn mower) on a single axle trailer. I"ve got a 12" tandem axle that my 8N fits on, just fine, but if I add any implements (4" brush hog, 6" disk) they hang off the back of the trailer. You didn"t mention the length of the trailer, but I don"t remember seeing many (any?) single axle trailers over 8" long.
Trailer brakes are a huge bonus. I"ve NOT got them on my 12", but wish I did (that"s on my "to do" list, rebuild that trailer and add brakes).
You might look into a weight distributing hitch for the truck, too...
Steve
Adam Paul
09-01-2004 21:56:23
Hello, I can speak with a good bit of authority on this one. I understand the math, the weight ratios, balance and have had a good bit of experience towing both utility trailers, and travel trailers. If you really want to gain a vast understanding of this, be sure to visit www.rv.net, and go to the towing forum.
First, DO NOT CENTER the tractor on the trailer. Move the tractor forward to the front side of the trailer. This will add tongue weight; this is good, as it prevents sway. Given the figures you provided, you will WANT a tongue weight of 285 pounds. You can actually use a heavy duty bathroom scale for this. You measure this weight at the tongue, not the jack. Second (by the way, these rules apply for all trailering), back your tractor onto the trailer. This gives you better weight movement, and is a safe tractoring practice. (You’ve got to back it up at some point anyway)
Third, while trailer manufactures talk about weight capacity of the trailer, few talk about the tires. You will have to look at the load range of the tires. From the sound of things, you don’t have trailer brakes. I tow with and with out brakes depending on what I’m towing. If you pay attention, and anticipate you should be OK.
Fourth, when ever you hit hilly terrain, tow in third. (Non-overdrive). You’ll know when you need to do this as the truck will tell you so. Towing in non-overdrive takes a minute to get used to. RPM’s go up, gas mileage goes down, it sounds louder than your used to. This is what you want. While towing, this is the best performance range for your engine, and transmission. It also, at higher speeds, offers engine braking.
A couple of other thoughts: Police CAN NOT pull you over for their judgment on WEIGHT. They can pull you over reckless driving, or endangering others. The dump truck mentioned in the other post was probably being off loaded because the tow vehicle broke down, or the driver was endangering others by way of some unsafe practice. It was NOT due to weight.
The biggest concern I see in your scenario, are the tires of the trailer, followed by not having brakes on the trailer. I also wonder if you are using the bumper for your hitch…
If it were me, I would tow it. However, that statement is made by saying I would make sure I had the right tires. If you ARE using a bumper hitch, I would install a receiver/hitch.
Hope that helps,
Adam Paul
john in la
09-02-2004 07:07:51
 Re: Hauling Ford 8N with small pickup in reply to Adam Paul, 09-01-2004 21:56:23
Like Paul said... Good post but have to say you Can get pulled over for weight.
Your states Weights and Standards can pull anyone over for weight and they do not even have to make it a judgment call. That is their job. They can stop every vehicle that passes them and check the weight just like a police officer can stop anyone and ask for a license and proof of insurance. The only thing that stops them is the fact that they get paid the same to sit in the A/C car as they do to tote portable scales all day.
Adam Paul
09-02-2004 09:37:39
 Re: Hauling Ford 8N with small pickup in reply to john in la, 09-02-2004 07:07:51
Very good points on the weight statement. There are weight laws and limits. For example, in the farming and commercial trades, their are weight restrictions placed on the license, or the vehicle registration. And there are laws regarding weight with the roadways themselves. I.E., the weight signs posted on small bridges.
However, for recreational purposes, which hauling a hobby tractor falls into, a cop can"t pull you over and say you’re over weight. (Just imagine how rude that would be if you"re a woman!!!) If I enjoyed the hobby of collecting tanks, I could with a regular license tow the tank, just so long as I don"t exceed the weight rating of the road, and I"m not endangering others. The police need "Just Cause" to pull you over (I"m not going to discuss holiday road blocks here), NOT "Just Felt Like It". "Just Cause" could be an unsafe, or illegal towing condition. Safety chains not "crossed" would be such a reason to be pulled over. My point is, you are not breaking the law, towing 12000 lbs with a Camry, just so long as you are doing it in a way as to not endanger others... By the way, you could safely tow 10K+ safely with a Camry, if a properly installed Hensley or Pull-rite hitch were to be used, combined with properly adjusted trailer brakes...
john in la
09-02-2004 10:28:14
 Re: Hauling Ford 8N with small pickup in reply to Adam Paul, 09-02-2004 09:37:39
You also make some good points but I think you are confusing DOT and weights and standards. Many do.
Yes if you are pulling a hobby tractor or RV the DOT can not really mess with you. They are for commercial haulers only. Now if you get into large trucks you better have some documentation that proves you are a hobby. Most will say they are a hobby but how many people do you know that can pay a $2000 a month note for a hobby truck. That gets real iffy if you pass that 26,000 lb threshold.
As far as weights and standards. While they may concentrate on large trucks because that is where the money is they can pull over a motor cycle to check them out. Not to say any officer can pull just any body over to harass them but if you were pulling a tank behind a Camry it would be very obvious that you were endangering my life. Just because it will pull it does not mean it will stop it or handle it at road speeds.
Another point is roads do not have weight limits in the sense you are stating. If a road is limited to 80,000 lbs that does not mean you can run a 2 ton truck at 80,000 lbs no more than you can run your Camry at 80,000 lbs. I do not care what kind of RV you want to call it. Axles have weight limits. Check that bridge sign again and you will see that it states different weights for different size vehicles.
That is like the person that goes to the big orange hardware store in a Camry. They buy 100 stepping stones and pile them in the trunk. The rear end is dragging and the front end is in the air. This person will drive slow and only has 10 miles to go so they think they are safe and are not endangering any one. Not exceeding the speed limit; all lights work; using turn signals ect ect. Can this person be pulled over??
I do not care if it is a very large woman. If it is over weight it is unsafe and that gives them probable cause. Even if it is not over weight they have probable cause because they think it is over weight.
One final note. If this woman with the stepping stones were to hit your wife and kids on her 10 mile trip home I would think you would see it in a different light. Just because weight and standards has better things to do than chase ever soccer mom out there; do not think they can not.
Adam Paul
09-02-2004 12:01:21
 Re: Hauling Ford 8N with small pickup in reply to john in la, 09-02-2004 10:28:14
Hey John,
I value your points as well. The 100 stepping-stones is a perfect example too. Here"s how I view it.
It was stated that all lights work. If the lights were pointed at the sky, and not the road, the vehicle would be in violation for the lights.
If the tail of the car were scrapping the ground, it would be a public fire hazard.
If bricks were falling out of the car, it would not be the fault of weight, but rather carelessness in the packing of the bricks.
I can relate to your story. Just a few months ago, a moron loaded a dishwasher in the back of a truck with no tailgate. It had bounced out while on the highway and killed a father of two... I really felt for that family...
Respectfully,
Adam
T_Bone
09-02-2004 09:55:08
Hi Adam,
I"ve posted this before for a good read.
My son went to Co. to pick up a 14ft bass boat his Grandfather gave him using his AZ, Ranger pick-up. He"s comes past the scales at Cortez, Co and heads south to the Four Corners. Just as he gets to Four corners about 70miles away, he gets pulled over by DOT;
DOT says "Why didn"t you scale at Cortez?
Son says "I was unware that trailers under 10,000lbs had to scale. Is this a spot check or something?"
DOT says "No, we help Game and Fish out and find most motor homes have over there limit in game. We noticed in the camera your AZ truck plate and the CO boat plate. You need to return to the Cortez scales, wheres your license"
Son hands his "CDL" license to the DOT officer.
About 10 minutes latter DOT officer comes back really pissed. My son is Federal Marshall and every time he gets stopped or questioned, his supervisor has to be notified. Read this as 4 hrs of paper work for the DOT officer :)
He "let him go" for being a fellow officer but got a chewing out for failing to indenifiy himself.
So anything is possible when dealing with DOT!
T_Bone
Adam Paul
09-02-2004 10:08:48
 Re: Hauling Ford 8N with small pickup in reply to T_Bone, 09-02-2004 09:55:08
Good read! Yes a lot is possible!!!
Good post above, and awesome call on the brakes over 1500 lbs. All of my road worthy rigs over 1500 lbs have brakes. I"m glad you reminded him, and passers through the tread.
PS, Why does your name seem so familiar?
Believe it or not, this is my first time on the "Tractor Talk" thread. Have I seen you at the Ford "N" board, Paint and body board, or an RV forum??? It seems that since you know what a TV is, you probably know what a TT is.....
Adam
T_Bone
09-02-2004 20:17:22
 Re: Hauling Ford 8N with small pickup in reply to Adam Paul, 09-02-2004 10:08:48
Hi adam,
Welcome To The forum :)
There used to be another t-bone on the 2n forum.
I usually wonder here or on the tool forum.
RV.net? yappers thats me!
T_Bone
paul
09-02-2004 11:39:59
Here in Minnesota, a "farm trailer" does not need a license if you are operating within 150 miles of the farm & hauling farm produce or supplies. The fedral regulations require all trailers be licensed. However, the state & county officers are in charge, & they follow MN law, not fedral law. It"s all in who does the enforcing.... You see all kinds of rigs out on the roads, as long as you have chains on & lights at night no one much bothers you.
In addition, farm equipment traveling under 30 mph basically only needs an orange triangle in the day, plus lights at night. Practically no other regulation - OTHER than weight limits.
So anyhow, my county (as well as the state) has a law that you can only have "x" amount of weight per inch width of tire on the county roads. In spring most county roads are posted for much lower weight ratings as the frost comes out and this is enforced as well.
I assure you, very, very much, that ANYONE in Minnesota can get pulled over _just_ to have their rig weighed. Only reason. And that includes a farm tractor pulling a grain wagon, through a semi / trailer combo. Or a car pulling a camper or cement blocks.
And my county intends to pay for the portable scales they bought last year, so understand, you _can_ get pulled over just for a weigh check. Any time, any where.
Enjoy your messages.
--->Paul
JT
09-02-2004 14:46:42
 Re: Hauling Ford 8N with small pickup in reply to paul, 09-02-2004 11:39:59
On all this DOT stuff, thye are being but heads about it. I have two salesman that come into my store, they haul lawn mowers, double axle trailers, brakes, the who thing, they get hasselled for not have their log books up to date. Cannot say I blame them, it is happening to eveyone.
paul
09-01-2004 23:26:40
Vehicles are pulled over all the time in MN for weighing. My county bought portable scales so they can weigh the farm vehicles on the county roads.
Other than that, good message.
--->Paul
jim
09-01-2004 21:30:35
You'll probably end up pulling the factory bumper off or at least bend it down till the hitch wedges. 350# tounge weight is not that much weight, especially when using a single axle trailer. Factory bumpers will not hold up to much abuse, especially tounge weight.
Loren-MN
09-01-2004 21:05:53
If you have the 3.0 V6, power is not an issue. I hauled the 8N many times behind my Nissan Quest mini van, with a 16ft tandem axle alumimum trailer. However, I had the rear suspension beefed up, electric brakes, and a transmission cooler added. Did this because I was alway pulling smaller utility trailers for work. My suggestion is get a tandem trailer. Too much sway with a single axle, and at least get surge brakes. By the way, I just sold that 1995 van with 217,000 miles, and still running strong. Loren-MN
Grant MD
09-01-2004 20:39:26
I guess you could legally, BUT like the other guys said, you have Very Little margin for error. Also, while you are alert while driving, other drivers may not be. The best planning cannot anticipate what will happen three states away from home. I would rent the bigger trailer, and look into borrowing a truck with a brake receiver. Good Luck.
Davis In SC
09-01-2004 20:08:43
It would probably be OK, but very little margin for wet road , sudden stops etc. I recently saw a Chevy dually with a flatbed tagalong trailer that had a Ford 8000 dump truck on it. State trooper had them pulled over on the interstate, & they were backing the Ford off the trailer. I would love to have heard that conversation..... ..
Dale M
09-01-2004 19:35:21
I hauled an 8n with the same type of trailer using a 1999 Chevy Blazer. It didn't seem to bother it a bit. Your 4x4 should pull it if you don't get crazy and fly down the road or around corners. Just drive safe and stay alert, remember it will take a little longer to stop The extra weight and could jack-knife the trailer if it starts to sway too bad. Try to center the weight over the axles if possible.
paul
09-01-2004 19:07:19
It looks like you legally could, if that is the true weight of your tractor - no fluid, no other implements or much stuff in the back of the pickup. (Probably would actually want a little weight back there as I think about it, you ain"t going to have any braking.....)
However, I would not _want_ to with a single axle trailer, as that thing is going to hop & bounce all over the place. This will be the most miserable ride of your life. Also I will assume you don"t have brakes on the trailer, & a couple thousand miles will cost you brake job, if you don"t crash out. Stopping distance will be difficult for you. I assume you will be on the interstates at 70-75, and you are taking everything to the max limits legally.
Certainly your call, but I"d look for a different way.
Now, if you bought it 100 miles away, then I"d say sure go for it. That"s a nice leasurly trip & you can be careful for 100 miles & not overdo things.
--->Paul
Doug in Minnesota
09-01-2004 19:23:32
 Re: Hauling Ford 8N with small pickup in reply to paul, 09-01-2004 19:07:19
Thanks Paul for the good advice. I guess I"ll look into renting/getting a bigger trailer with brakes. Any suggestions? I guess I"ll need a bigger truck too, right?
TheRealRon
09-02-2004 01:12:09
 Re: Hauling Ford 8N with small pickup in reply to Doug in Minnesota, 09-01-2004 19:23:32
You are smart to do the math first and ask questions. You saved yourself a big headache. Just ignore the "advice" about not getting stopped for weight violations. It's great sport in my state and many others.
Here's another approach. It's expensive but solves a lot of problems. Call the national moving truck rental outfits. Find out what it would cost to rent a small moving truck and car hauler. They won't let you off the lot with a mismatched tow vehicle/trailer. If you fry the AT or have other problems, they aren't your problems. Get the damage insurance they offer. Load the tractor and drive around town a bit the day before you will leave on the trip. Practice backing, turning, braking in a large parking lot. Become aware of those nasty overhead objects at gas stations etc. They have signs and the rental truck has a height marked on it. Take your time on the trip and be very aware of high lateral winds. Box vans get moved around quite a bit and you have to pay attention.
Adam Paul
09-02-2004 09:42:54
 Re: Hauling Ford 8N with small pickup in reply to TheRealRon, 09-02-2004 01:12:09
He will NOT have a weight violation...
And he will not have transmission problems if he doesn"t already.
See my above post.
Respectfully,
Adam
TheRealRon
09-02-2004 11:31:22
 Re: Hauling Ford 8N with small pickup in reply to Adam Paul, 09-02-2004 09:42:54
Sorry, but he's at least 1,000 lb. over the GCWR. Do the math.
Trailer = 1,500
Tractor = 2,600
Nissan 4x4 = 4,600 (approx., incl. people, fluids, and stuff).
His GCWR is 7,700 so he's at least 1,000 lb. over. In my state they seize the whole deal. As well they should... overweight towing is a danger to perfectly innocent people and totally indefensible.
The most common cause of premature AT failure is overheating due to towing. True even with the correct axle ratios and tranny cooler which he most likley does not have.
Adam Paul
09-02-2004 12:18:01
 Re: Hauling Ford 8N with small pickup in reply to TheRealRon, 09-02-2004 11:31:22
Ron, with all due respect, I would LOVE to see a cop tell me the towing capacity of my tow vehicle, or his Nissan... While you most certainly have a great point, an officer of the law cannot make the weight rating or towing capacity determination of his, yours or my tow vehicle.
What if he uses air bags, or additional springs??? See what I mean here. For this application, and being in a non-commercial, passenger class, he WILL NOT be in weight violation. If an officer were to give him a ticket for over weight, towing an 8N the officer should gladly accept a lawsuit for harassment.
Respectfully,
Adam
TheRealRon
09-02-2004 13:42:45
 Re: Hauling Ford 8N with small pickup in reply to Adam Paul, 09-02-2004 12:18:01
You seem like a nice guy but you know absolutely nothing about the subject.
For many years, all the auto/truck manufacturers have been required BY LAW to provide the US-DOT with all the weight ratings for each vehicle they produce by VIN#. This info goes into a database every cop in the US has access to. That's why when you get stopped they run your VIN#. Ever notice the "bar coding" on your VIN plate? Lots of jurisdictions have bar code readers on their hand-helds and they know more about your truck in 5 seconds that you will ever know.
All the aftermarket garbage you mentioned has ZERO effect on the weight ratings.
Any cop anywhere in this country can stop you for any reason he wants, including no reason. They just make one up. If you cock-off to a cop in my state about his ability to ticket you, you will likely get a Mag-Lite in a place you would not normally expect to find one. At that point, it's "obstructing law enforcement" and 1 year in the slammer. Pales in comparison to the minimum $2,250 fine for overweight operation.
Adam Paul
09-02-2004 15:01:31
 Re: Hauling Ford 8N with small pickup in reply to TheRealRon, 09-02-2004 13:42:45
Ron, Thank you for mentioning I"m a nice guy, I"m sure you are too!!!
I"m not even going to respond to your post, I"m in a friendly way going to suggest you read up on the laws. Perhaps one day at some tractor show somewhere, we can kick it and talk about all the things we"ve learned.... I"ll even buy the first round of beverages...
Once again, Respectfully,
Adam
ed1
09-02-2004 10:58:51
Adam
I respectively disagree.
First, the type of drivers license you have makes a difference.
Second, the registered weight also has an impact
Third, Cops are smart enough to pull you over for something else to check your situation out.
IF you have a CDL you can most certainly be pulled over and asked for your log book and weighed if the officer wants. You are also cannot pass a weight station with our being weighed or instructed to pass.
With a passenger car license their more easy going – no logbook or weight station requirement.
Next, a vehicle towing more weight than it’s designed for will sway especially if the trailer is 3 or 4 times over the weight capacity of the towing vehicle. If you have a CDL this equals JAIL – not sure what it means for a passenger car drivers license. Excessive swaying = reckless driving – you most certainly be pulled over for that - the cop can even arrest you and impound the vehicle and trailer if he feels it’s necessary.
Their is also the 10,000 # question that is not at all clear. The federal govt. says you need a CDL plus endorsements to pull a trailer weighing 10,000 or more, most states use a combined weight - NY is 26,000#.
Safety, I certainly would not feel comfortable driving a 1,000 or 2,000 uni-body frame (basically a beer can) with a 12,000# trailer. I want a frame and a little more weight. Even my F-350 will have trouble stopping my loaded 9,998# trailer if the trailer brakes are not adjusted properly. Let’s not forget that 500# or 1,000# tongue weight becomes a lot more when braking - I wouldn’t be surprised if the trailer ripped the hitch right off the car. Light sheet metal simply can’t support the amount of weight that shifts forward when breaking. Also remember an evenly or close to balanced trailer will sway more.
As far as the engine and trans. go – it’s counter intuitive to believe exceeding a towing vehicles capacity by 3 or 4x will not have an impact on reliability. The V6 with a different trans and gear rations might be ok but the trans simply will not. Motor and trans mounts might be the first to go but couldn’t rule out chipping a gear or two.
Adam, you’re correct in pointing out their are a number of loopholes in the law for those that have only a passenger car driver’s license. I hope that some dummy doesn’t mess it up and make everyone’s life more difficult. It only takes one major accident to make headlines and put pressure on our legislatures make some stupid law that doesn’t fix the problem and makes our lives more difficult. Their probably should be a non-commercial license to pull a trailer where the driver has to show good common sense and the ability to handle what he is driving.
On the common sense front – anyone pulling a 12,000 # trailer with a Camery could not only be pulled over but taken away by the guy’s with the little white jackets. You would have to be more than a little crazy to risk your life like this.
Davis In SC
I’d like to know more about the dually. I thought they could handle some serious weight. Ford 8000’s are big but didn’t think they were that heavy - I could be wrong - Or possibly the high sides made it sway more.
Would like to know more
Davis In SC
09-02-2004 17:05:47
 Re: Hauling Ford 8N with small pickup in reply to ed1, 09-02-2004 10:58:51
Ed, On the subject of the dually pulling the Ford 8000 dump..... My calculations... Ford 15,000 lbs, dually 8,000 lbs,( It was dressed up) trailer 4,000, occupants & misc 1,000....for a total of 28,000.... well over the CDL limit.I figure the Trooper pulled him just based on the size of the load vesus the size of the pulling vehicle. If he had been hauling a huge chunk of lead weighing more the trooper might never have noticed him. I know the max GCVW of my Dodge dually is around 23,000. When I pull my skidsteer on a gooseneck, I am around 17,000 , & really don't care to pull anything heavier than that.
ed1
09-06-2004 19:45:33
 Re: Hauling Ford 8N with small pickup in reply to Davis In SC, 09-02-2004 17:05:47
Davis
Thanks, guess I was a little off on the Ford 8000 weight.
Adam Paul
09-02-2004 11:21:04
Ed, You have a lot of great points!
The "loopholes" here are exactly as you mentioned. My point, it"s not the weight that will get you stopped (passenger use), it"s the careless driving. Also I forgot what the cut-off was, 10,000 or 12,000 lbs, you reminded me it was 10K, Thank you. The "Camry" example was just that. Also note, I mentioned the use of a Hensley or Pull-rite hitch. No sway with theses hitches... Why? Because the hitch is mounted far under the tow vehicle above the rear axel, and the trailer in a sense has it"s tongue moved forward. The most popular use of these hitches is when a car like an Intrepid, or Caddy is towing a 9500 lb Airstream.
One last thought, I would hate to see some a$$ forget the common sense, and give us some new law!!!
Respectfully,
Adam
