Tractor Talk Discussion Forum
69 Mack Pinion Gear Bearing Problem
Darrel
09-02-2004 15:28:51
I'm replacing the pinion gear bearing on a 69 Mack. I cut the old bearing off, but having a problem getting the new one on. Is there an easy way?
Darrel
ohio dick
09-02-2004 21:02:31
 Re: 69 Mack Pinion Gear Bearing Problem in reply to Darrel, 09-02-2004 15:28:51
Hi i work at a mack dealership. We heat the bearings to install on the pinion and spur gear. I use a torch and steel plate .Carefully heat to 300 will slip right on.
T_Bone
09-02-2004 20:11:23
Hi Darrel,
Freezing the pinon shaft should gain you about .002 smaller.
T_Bone
Davis In SC
09-02-2004 19:12:58
A bearing heater would help prevent damaging bearing and/or shaft during installation.
Fudd
09-02-2004 18:31:16
I would think you have to press it on with a press.
