Tractor Talk Discussion Forum
Convert Belarus 12 volt to 24 volt
Jb
09-03-2004 07:09:54
Does anyone have a schematic or sketch for conversion of a Belarus 570 to 12 volts? I know the high current relay is removed and the batteries are connected in parallel before changing to a 12 volt starter but do not know the other details.
Any help appreciated.
Trkr
09-03-2004 12:09:22
 Re: Convert Belarus 12 volt to 24 volt in reply to Jb, 09-03-2004 07:09:54
All I did to ours (820)was hook the batteries in parallel and put a 12 volt starter on it.Uesd a test lite to find a hot wire for when the key was turned to start to the small leg on the solenoid.Hooked the positive battery cable to the starter direct to the positive side of the batteries,unhooking it from the parallel switch.
jb
09-04-2004 19:14:11
 Re: Convert Belarus 12 volt to 24 volt in reply to Trkr, 09-03-2004 12:09:22
Thanks TRKR,, Will keep this in file.
