Tractor Talk Discussion Forum
1954 M-H Model 33 gas
Jack D
09-04-2004 04:46:31
Hi there,
I've just purchased an old tractor and know next to nothing about them, I got it cheap and took a chance on it.I'm overall very pleased with it but it has a small nagging problem. The tractor starts really well when cold but if I don't close the gas valve when I stop it (Even if it's for a short period)it floods and is really hard to start again and then does not respond very well to the throttle lever. Any Idea??
Thanks a lot in advance.
JD
Alberta Mike
09-04-2004 05:58:21
 Re: 1954 M-H Model 33 gas in reply to Jack D, 09-04-2004 04:46:31
Sounds like the needle and seat in the carb might need replacing, or maybe some crud has found it's way in there and is keeping the float needle stuck open a bit. The float level might also need adjusting. Tear the carb down, clean everything up and reassemble it as a first step. Be careful when you separate the two halves of the carb so you don't tear the gasket (although you can cut another one). Also, don't attempt to remove any brass screws or jets for now or disaster will strike. Email me if you wish, I have removed the hide feature on my name link.
