Tractor Talk Discussion Forum
54 ford naa clutch won't engauge
Josh Sidwell
09-05-2004 17:40:54
I just got though replaceing the clutch,pressure plate, throw out bearing, and resurfaced the flywheel. I adjusted the pedal and have a good pedal per the shop book. The clutch just won"t engauge. I press the pedal and the gears grind and won"t go in gear. HELP. Any sugestions? Josh
Bob
09-05-2004 21:36:46
 Re: 54 ford naa clutch won't engauge in reply to Josh Sidwell, 09-05-2004 17:40:54
Correction...
The clutch won't DISENGAGE.
Trucker
09-05-2004 20:44:56
Sounds like you could have put the disc in backwards.On most things the side of the disc that has the springs on it,and the plate that holds the springs in the disc,goes into the pressure plate,or the part of the disc that has the long portion of the hub that the splines fit in goes towards the transmission.Either the hub wont allow the plate to go in place right,or on clutches with springs in the disc,they wont fit into the flywheel and it holds the plate away from the flywheel.Also the plate is usually marked with a sticker that says flywheel side or pressure plate side,a few times Ive seen them be wrong.If you split the tractor again,thats what I would look atif the plate that holds the springs is facing you,or the hub that the splines go in is kind of tapered then chances are its in right and the problem is something else.
TheRealRon
09-05-2004 18:17:20
1) Wrong clutch disk or installed backwards
2) Wrong/damaged pressure plate
3) Damaged splines on input shaft
4) Wrong/damaged/worn pilot bushing
5) Release fork damaged/misaligned
6) Improper linkage/free play adjustment
