Mornin' Ron, Call me thick-headed if you want; but I just don't see how an automatic adjuster can ever, under any circumstances, "over tighten". If it were to be installed "backwards" (end for end) it would, of course, be totally inoperable. If a left side adjuster were installed in a right side drum (or the other way around), it would be forever "ratcheting" on the pull-stroke and would not tighten a thing. But, even if the star wheel were indeed moving on the ‘slop’ stroke, it would be always trying to “loosen” the brakes, because the threads of it’s shaft and barrel are backwards (left vs right sides). Further, by their very design, an automatic adjuster needs lateral "movement" of the shoe(s) assembly against the backing plate to obtain it's throw. Additionally, since the adjuster assembly is always located at the secondary shoe, this ‘movement’ has to come as a result of the shoes being applied while the vehicle is moving in reverse. Take it a step further: If the whole she-bang (backing plate, shoe assembly, and the drum) were switched left to right (which is impossible, because of the e-brake cable mounting), the adjuster would indeed engage during brake application during forward motion (if there were enough movement of the shoe assembly against the backing plate). However, it would still only adjust to the “correct” tightness and would not “over tighten”. The upshot of all this is that the tighter the shoes get to the drum, the less the adjuster mechanism moves until it reaches a point of not moving at all. Can ya help me out on this one, 'cause my old pee-brain just can't grab the concept. How could an automatic adjuster ever possibly over tighten? Allan
