Tractor Talk Discussion Forum
Fastest Stock Tractor in the U.S.?
Larry Kastens
09-06-2004 11:07:58
Which tractor, made before 1950, made in the U.S., had the fastest road gear as it came from the factory?
Thanks.
p55
09-07-2004 05:12:13
 Re: Fastest Stock Tractor in the U.S.? in reply to Larry Kastens, 09-06-2004 11:07:58
The Love and the Friday, both with Chrysler-built 6-cylinder engines, 5 speed New Process transmissions and two-speed rear ends, from the factory, had running speeds, listed, at 42 m.p.h.
on 12x24 rear tires in the 1947-1949 sales literature. (Both would exceed that if you had the intestinal fortitude to withstand it !)
Pete - IN
09-06-2004 17:19:35
Two models I have driven made before 1950 and really fast on the road would be the Number 2 Co-Op and a 3 wheel Silver King. Both would run close to 40 MPH and really make a hay wagon sway behind it. Of course I was a tad younger and a lot crazyer back then.
Chances R
09-06-2004 17:17:09
third party image
Just to let you know you might want to do a search on this topic here at YT. I read in Antique Power that there use to be tractor oval track racing. There was a Simpson that would hit 80 mph if I remember the article right. I know my Custom will get with the program and its almost the same tractor.
Jon H
09-06-2004 15:37:37
This might qualify. This is a copy/paste from the www.tractorace.com site.
"By 1930, in spite of the growing depression, more than 900,000 tractors were in use on U.S. farms -- nearly double the number in 1925. The Case Model DD was introduced that year, and is a good example of two trends that were current in the tractor business. It had three wheels instead of four, to make cultivation or row crops easier, and it was a general purpose tractor. Another idea just coming into vogue, though not on this model, was rubber tires, which gave farmers a smoother ride and more speed. Race driver Barney Oldfield about this time drove a rubber-tired tractor 64 mph, and once got a speeding ticket while driving a tractor through a small town in Indiana."
Jon H
09-06-2004 15:42:08
 Re: Fastest Stock Tractor in the U.S.? in reply to Jon H, 09-06-2004 15:37:37
Sorry,that addy was not correct. Here is the addy for a lot of interesting tractor stuff.
Redman
09-06-2004 15:10:50
i believe the UDLX MM would be in the running.
TGIN
09-06-2004 14:38:43
I think Ron is thinking of the Co-op no.1 . The Friday tractor was a fast one to and it has been on RFD also I think the Friday is put together with Dodge truck trans. and rearend .
TheRealRon
09-06-2004 14:08:06
This was just stated on RFD-TV. They even showed a clip of the tractor. Of course I don't remember the make but I do remember they said something about 45 mph!
thurlow
09-06-2004 13:46:30
Essex Tri-D, probably; can't really tell because of the lack of documentation for serial numbers/year of manufacture..... ..
Country Lad
09-06-2004 17:10:54
 Re: Fastest Stock Tractor in the U.S.? in reply to thurlow, 09-06-2004 13:46:30
I think it was an essex that I passed with my WC allis which I kicked out of gear with a hay baler. Kinda made the Essex driver mad that I passed him. Neighbor did not keep his ezzex long because he wrecked it and the cultivator.
evielboweviel
09-06-2004 14:05:42
the ETD was so fast it got there hours before it left the starting point
Ron
Yes
09-06-2004 15:07:52
 Re: Fastest Stock Tractor in the U.S.? in reply to evielboweviel, 09-06-2004 14:05:42
I have herd people say that it would harvest crops before they were planted while greatly increasing yield.
Jeff Oliver
09-06-2004 20:37:12
 Re: Fastest Stock Tractor in the U.S.? in reply to Yes, 09-06-2004 15:07:52
And on that note I also have a diesel truck that gets so good mpg while towing my tractors that we have to stop every 200 miles to drain the fuel tank so it won't run over! LMAO!!!!
Sorry but I couldn't resist.:)
ErnieD
09-06-2004 11:25:33
Silver King was pretty fast. Don't know if it was before 1950 tho.
Mike M
09-06-2004 16:34:49
 Re: Fastest Stock Tractor in the U.S.? in reply to ErnieD, 09-06-2004 11:25:33
Silver King gets my vote. I had a three wheel once and I wasn't brave or crazy enough to open it all the way up on the road.
