Tractor Talk Discussion Forum
1955 International Cub Overheating
Cubby
09-06-2004 16:56:54
When tractor reaches operating temp it starts to belch anti-freeze from overflow tube - especially when going down inclines or hills.
John *.?-!.* cub owner
09-06-2004 18:51:34
 Re: 1955 International Cub Overheating in reply to Cubby, 09-06-2004 16:56:54
It is a thermosyphon sytem and you are probably overfilling it. The ormal level is about 1 1/2 inches below the filler neck. since there is no water pump it expands quite a bit as the engine runs and heats up causing it to "belch" the anti freeze out.
k.n.
09-06-2004 21:15:30
 Re: 1955 International Cub Overheating in reply to John *.?-!.* cub owner, 09-06-2004 18:51:34
my experince with heating problems with a cub would be to take the raditor off, under it you will find that the holding tank is full.the stuf you find will supprise you.
