Tractor Talk Discussion Forum
massey harris 44
delbert lewis
09-09-2004 14:57:43
Hello ; I just bought a massey 44 it has no hyd. Is there any way i can put hyd and three point on it or am i stuck with a puller. Thanks Delbert
Randy Varilek
09-11-2004 21:49:47
 Re: massey harris 44 in reply to delbert lewis, 09-09-2004 14:57:43
Delbert,
I have the factory pump and lift cylinder and valve assembly but I don't have the three point arms and rockshaft. let me know if I can help.
delbert
09-12-2004 20:16:21
 Re: massey harris 44 in reply to Randy Varilek, 09-11-2004 21:49:47
yes im intrested in parts you have randy please email me at leelewis@srcaccees.net
delbert
09-10-2004 06:19:59
thanks for all the help so far but i need all the help i can get foe i no nothing abought masseys. thanks again delbert P.S. it is a 4 cyl.
marlowe
09-09-2004 18:21:21
yes you can put a 3pt. on it IF you can find one they are hard to come by and if yours is the 4cyl. 44 and not the 6cyl. you can add a pump to the front left where the oil fill is the pump runs off the cam shaft and they are not real easy to find but with a little or a lot of looking you should find what you need
Delbert
09-09-2004 18:01:14
Delbert i don,t have any idea about your tractor but i,m sure glad to know that there is another Delbert out there.Not many of us that i know of. Good luck with your 44 i,m sure you will get a lot of good advice.
