Tractor Talk Discussion Forum
tractor shut down
Henk
09-10-2004 13:26:24
After working my AC B hard for about a hour it shuts down and we have to wait for it to cool down before it will start again does anyone know how to solve this.
RAB
09-11-2004 00:14:43
 Re: tractor shut down in reply to Henk, 09-10-2004 13:26:24
A couple of things to keep in mind.
Is it dificult to start when hot anyway?
Check it out before spending money.
You can check if it is short of fuel to the carb by draining fuel (safely) for about a minute when the problem occurs - there should be a non-diminishing full flow.
Check for spark immediately after it quits. If there is a strong blue spark, it ain"t the electrics!
Ron"s suggestion of releasing the fuel cap is a zero-cost option, but buying a new coil, if that is not the fault, will simply cost you for no return whatsoever. So check first!!
Regards, RAB
TheRealRon
09-10-2004 13:42:49
Next time it happens immediately remove the gas cap. If the engine will then start, the vent in the gas cap is plugged. If it won't start, replace the coil. 99% of the time it's one of those two things.
TimV
09-10-2004 13:34:47
Hank: I don't know much about the AC B specifically, but in general, that's a classic symptom of a bad coil or condenser.
