Tractor Talk Discussion Forum
John Deere LX176 question
Elsa Lankford
09-10-2004 15:26:41
Hi, I apologize for the oddness of this question, but our LX176 isn't starting up. The battery seems OK, but the engine never turns over.
In opening up the hood, there are 2 yellow wires running along the left-side of the engine. The yellow wire with a black stripe is hooked up, the plain yellow wire is unhooked. I'm guessing that this is the problem. I'm just wondering what it's supposed to be hooked to, and if this sounded like a reasonable cause of the problem The B&W picture in the manual is not very clear.
Thanks,
Elsa
cannonball
09-11-2004 05:18:27
 Re: John Deere LX176 question in reply to Elsa Lankford, 09-10-2004 15:26:41
be sure the mower deck switch is off...will not start with it on....you could get test light and hook up to wire and see if it lights up when you turn switch if not try it where you think it plugs in and try switch..if light comes on plug in and try..have nice day may god bless
TheRealRon
09-11-2004 02:39:50
There is a garden tractor discussion group here and if you post there no doubt someone will have that lawn tractor and be able to answer your question.
Jerry Bliler
09-10-2004 21:01:17
You need to check the seat saftey switch and the brake pedal switch before you go too far. Both of these will kill the ability to start the motor. Seat switch will also kill motor when you get off. Good luck, If you give up I need the carburator
