Tractor Talk Discussion Forum
Ford industrial tractor
Michael Bright
06-20-2007 12:26:39
I just purchased a 1968? ford industrial tractor with #723 backhoe and #730? loader with a model # on the data plate as CA 212K and serial # 0538966. Just received the serial # manual but no info. HELP, I need parts but need to know what I have. Thanks a million.
Rick from NC
06-20-2007 18:40:48
 Re: Ford industrial tractor in reply to Michael Bright, 06-20-2007 12:26:39
If your serial number is 538966 that would put the tractor after 1975. The '0' at the start of the serial number may be a 'C' indicating US built. I don't have any information on model numbers for the tractors made after '75. You may post this info down on the Ford board and get more answers.
The 7E04B number from the bellhousing in your other post is a production code which indicates it was built in 1977 (or '67) on May 4th on day shift. You can find these numbers on most of the castings on the tractor.
The link has info on '75 & earlier thousand series tractors.
