Tractor Talk Discussion Forum
Rear Tires
Mr. Ugly
09-13-2004 07:26:58
MY 1959 MF65 rear tires are showing their age. I want to squeeze out the rest of the season on them. One is filled with water. Question: can I top off the rest of the pressure in that tire using AIR?
Leland
09-13-2004 17:04:28
 Re: Rear Tires in reply to Mr. Ugly, 09-13-2004 07:26:58
Mr what the rest of these pranksters forgot to tell you you may need new valve stems,used to work in tire shop and the stems will leak on older valves these are a cheap replacment item at any farm store. just make sure valve is on top that way if it leaks you won't lose much fluid. then add 18-20 lbs of air more than enough.
ben uk
09-13-2004 10:18:48
I also have a question about this, do i need to put some sort of an adaoter on my air line to stick a nit more air into my liquid filled tires? Or just park it with the valve at the top?
Thanks in advance
Ben
TheRealRon
09-13-2004 10:30:09
 Re: Rear Tires in reply to ben uk, 09-13-2004 10:18:48
When tires are filled with liquid ballast they are filled only 3/4 of the way as water doesn't compress and you would destroy the tire and/or the rim the first time you hit a bump. The other 1/4 is obviously air so just position the valve at the top and fill like any other tire.
thurlow
09-13-2004 09:16:12
You guys totally wipe me out..... I'm considered something of a "wit" in my circle of friends, but I'm out of my league here. Usually it's the answers which have me laughing 'til I cry, but you've topped them all..... I've got to go see about an 18.4 x 38 tire this afternoon.....can't wait to tell the guys at the tire shop. Putting air in a tractor tire.....
mmb
09-13-2004 09:27:14
 Re: Rear Tires in reply to thurlow, 09-13-2004 09:16:12
While you were learning to be witty, you didn't read the post very carefully.
RAB
09-13-2004 08:27:21
A couple of things. If it is filled with calcium chloride solution beware that any leaks could seriously corrode your rim. If is water, I hope you are in a frost-free climate.
The tyre should only be filled to the level of the valve, while at the top of the wheel. The tyre is then inflated with air. A tyre completely full of liuid could be dangerous as liquids are non-compressible. regards, RAB
old
09-13-2004 08:23:34
Yes the water is weight only air preasure hold it up
All
09-13-2004 12:34:54
 Re: Rear Tires in reply to old, 09-13-2004 08:23:34
Thanks guys, I'll rotate the wheel to the top and put in some air. Hopefully, it the old tire will get me through the next few months and I can replace in spring!!
Jimmy King
09-13-2004 10:33:05
Old where have you been,I have put 2 post on here and got no responces, to see if any one knew.
old
09-13-2004 21:50:29
 Re: Rear Tires in reply to Jimmy King, 09-13-2004 10:33:05
By the way is King your real last name if so I may know you
old
09-13-2004 21:34:36
sorry I haven't been on much lately. I have been trying to get to many irons and Haven't had enough fire. I unhid my e-mail so send me one some time.
