Tractor Talk Discussion Forum
Novice needs help with toplink
Phil from Maryl
09-13-2004 11:03:08
Have bought my first implement, a 6 ft 3 pt blade. My tractors do not have top links. COuld someone tell me what I need to look for when buying a toplink for the 3 pt? Is it pretty much dummy proof or do I need to buy a specific size? Are top links specific to my tractor or are they universal?
Thanks in advance.
Phil
paul
09-13-2004 19:50:34
 Re: Novice needs help with toplink in reply to Phil from Maryland, 09-13-2004 11:03:08
I guess I would not say you don't have a top link on the tractor. You just don't have the top link. Some tractors come without a 3pt - either nothing at all, or some other idea like fasthitch, eagle hitch, snap coupler, etc.
So, you need to buy a toplink. There are kind of all sizes, but you are looking for a cat 1 top link, probably the average size one. There is a short one available also, you might possibly find a use for that too, but just guessing you will need the average size. Longer yest are typically actually for cat 2 hitches.... Measure as someone else suggested.
Any farm supply store should have some to choose from.
--->Paul
Phil from MD
09-14-2004 09:04:31
 Re: Novice needs help with toplink in reply to paul, 09-13-2004 19:50:34
I bought one from the local NH dealer. Funny thing it is blue and tractor is red... :-)
But it works great!! It is adjustable for size and has a hold down pin so it dosen't rattle around when not being used.
Thanks to all!
Phil
Joe MD
09-13-2004 11:45:43
Phil,
You will want to hook up your blade to the bottom two points of your 3-point and then measure the distance from the top link connection on your tractor to the top link connection on the blade.
You will want to take this measurement with the blade perpendicular to the ground.
This doesn't have to be an exact measurement, but a ballpark. Sounds like you have Category 1 machines and Category 1 top links come in a variety of lengths.
Have Fun,
Joe (Also from Maryland)
John S-B
09-13-2004 11:10:02
What kind of tractor do you have? Are you sure it has a three point hitch? If it does all you need to do is go to a farm supply store and get a toplink that matches the same category as your hitch, cat. 1, cat. 2, etc. ( cat. is the size ) The farm store should be able to help you. Make sure you learn how to safely operate your equipment.
Phil from Maryland
09-13-2004 11:16:33
 Re: Novice needs help with toplink in reply to John S-B, 09-13-2004 11:10:02
I have both a Ford 881 and a International 404. Both Cat 1 3 pt hitches. Yes, I have studied the owners manual very carefully and have practiced safe operation.
I will take it slow with the new implements I will be getting until I get more familiar with them. I am very safety aware.
Thanks
Phil
