Tractor Talk Discussion Forum
Re: Alternatives to CaCl in tires....
Indydirtfarmer
09-14-2004 15:55:01
We do about 400 hours worth of bush hogging a summer, for a couple commercial real estate brokers in the Louisville area. My son, or me one, is on a tractor just about every day. We hit bicycle frames, car rims, boards full of nails, concrete blocks, dead dogs, ect..... We end up with about 15 to 20 flats a year. Most are front tires, but so far this year, I've fixed 4 flat rear tires. I'm shopping for a new tractor for my son to run next year. (65 to 75 HP, cab w/ AC) We will foam-fill the tires....NO MORE FLATS! John
Leland
09-14-2004 20:56:46
 Re: Alternatives to CaCl in tires.... in reply to Indydirtfarmer, 09-14-2004 15:55:01
I hope you plan on trailering this tractor foam filled tires won't last long on pavment. Had a 544 deere with foam rode real rough and tires can't handle road speeds very well rubber breaks off, and the tires don't float anymore so plan on pulling him out of soft ground a lot.
TheRealRon
09-15-2004 05:31:54
 Re: Alternatives to CaCl in tires.... in reply to Leland, 09-14-2004 20:56:46
Good point. I use www.ultraseal.com in all my tires. www.gemplers.com sells it. The high-speed grade (trucks) seals to 1/4". The low-speed grade (tractors) seals to 1/2". It's standard equipment on military Humvees. It's saved me several times. Not cheap but cheaper than fixing flats.
Indydirtfarmer
09-15-2004 05:01:17
I don't do any bush hogging on paved roads. The tractor will be hauled everywhere, and with fluid in the tires, there isn't any flotation anyway, so that won't be any different. We run foam in one tractor now. It's worked out just fine. John
al boulais
09-14-2004 16:34:04
i use drain antifreeze most service stations are happy to get rid of it ten years never had a problem has rust inhibitors its free
JT
09-14-2004 16:57:37
 Re: Alternatives to CaCl in tires.... in reply to al boulais, 09-14-2004 16:34:04
and if you use antifreeze and the tires gets a leak, are you ready to accept the responsibility of ground water contamination, or the pets you could kill???? Antifreeze is a very dangerous product to use for this situation.
Ben in KY
09-15-2004 06:38:30
 Re: Alternatives to CaCl in tires.... in reply to JT, 09-14-2004 16:57:37
The new non toxic antifreeze seems to be about the same as using CaCl in my area. Figure at about 3.00/gal. $6.00 gal for the non toxic antifreeze mixed 50% = 3.00/gal. No rim rot either.
