Tractor Talk Discussion Forum
Re: Alternatives to CaCl in tires....
Leland
09-14-2004 20:56:46
I hope you plan on trailering this tractor foam filled tires won't last long on pavment. Had a 544 deere with foam rode real rough and tires can't handle road speeds very well rubber breaks off, and the tires don't float anymore so plan on pulling him out of soft ground a lot.
TheRealRon
09-15-2004 05:31:54
 Re: Alternatives to CaCl in tires.... in reply to Leland, 09-14-2004 20:56:46
Good point. I use www.ultraseal.com in all my tires. www.gemplers.com sells it. The high-speed grade (trucks) seals to 1/4". The low-speed grade (tractors) seals to 1/2". It's standard equipment on military Humvees. It's saved me several times. Not cheap but cheaper than fixing flats.
Indydirtfarmer
09-15-2004 05:01:17
I don't do any bush hogging on paved roads. The tractor will be hauled everywhere, and with fluid in the tires, there isn't any flotation anyway, so that won't be any different. We run foam in one tractor now. It's worked out just fine. John
