Tractor Talk Discussion Forum
case/david brown 1210 trans
jim on van isle
09-16-2004 13:11:58
could someone tell me what positions the gear shifters should be in for the 12 speeds this tractor has ? it has 2 sticks with 4 positions on the left on & 3 on the right. a guy almost needs a computor to figure out a higher or lower gear when operating due to so many combinations thanks
joe e-tx
09-17-2004 07:43:32
 Re: case/david brown 1210 trans in reply to jim on van isle, 09-16-2004 13:11:58
you need decal that came on top of dash (back of hood).does not work 1---12.i think i have a chart in my operators manual,will try to e-mail copy.i use high left lever forward but notpushed to left and forward and low left lever stright back from high.there is no stright forward shifting pattern.will get back to you.
joe
Les
09-16-2004 15:41:36
Where on V.I. are you? I am in Ladysmith.
TomTX
09-16-2004 15:07:37
If you repost your question on the Case forum, a guy called Elmer will help you. He is a DB expert and you can get manuals from him.
