Tractor Talk Discussion Forum
How to get grease fittings to take grease?
shocker69
09-18-2004 12:08:24
I have always had a hard time getting old equiptment greased what is the best solvent to put in hole after you take alimite out if it is stopped up w/ dirt,grime etc.I bought a Greasebuster from Shoup but it don't seem to work well.What do you do?
JHesler
09-20-2004 07:52:07
 Re: How to get grease fittings to take grease? in reply to shocker69, 09-18-2004 12:08:24
Most of the time you can remove them and scrape the dried up crud out of the part. I had a king pin that wouldn't take grease even after cleaning. I took the check valve out of a zerk fitting (grind a little off the threaded end, they're hard)put a tube on the fitting and filled it with kroil. After a few days i was able to get grease flowing through the part.
Mark - IN.
09-19-2004 07:25:50
Ron's right on the money. New grease zerks cost pennies, take little time to replace. Replace them. And make sure your grease gun is seated on the zerk properly. Oughta work just like that.
TheRealRon
09-19-2004 04:18:42
If the fitting has dirt in it, replace it. It makes no sense to force dirt into a part you're trying to lubricate.
If you are dealing with old, solidified grease, any auto parts store will sell you a hand impact tool that you fill with oil and whack with a hammer that frees them up every time. Be sure to get one with a flexible hose to get at those fittigs you can't get at straight on.
Davis In SC
09-18-2004 22:24:30
Might not be common..... but only way I can get the fittings for the kingpin on my MF 245 to take grease is to lift weight off of it....I just pick it up with the bucket of the skidsteer , & grease goes in easy..... ...
thejdman01
09-18-2004 20:11:01
definitly use kroil. its called areo kroil it puts wd-40 pb blaster etc to shame. the stuff is very very very expensive but worth every penny. never found the stuff at stores only over mail. it is make by kano lab"s. in fact the website is>Link
personally>Link i recommend
Weatherpruf Clear Rust Preventative - 1 Year Protection
Prevox Rust Preventative and Lubricant
Exrust Rust Remover - Fast - Easy to Use yes those are the correct spellings. i know aloto of people got alot of "penetraiting oils" and everyones got the "best". but ive honestly used pb blaster liqued wrench wd 40 etc ect alot alot and this stuff honestly works. i know from experience not from word of mouth. i also have a grease buster from shoup it may take 3-6 times squirt some in wait for air bubbles to settle fill settle etc pound it in 3-6 times or as many as it need and it will work. patience is a virtue. also dont know waht you are doing but somtimes changing the position or weight distribution sometimes help somthing take some greese. off hand i can think of the disc we got youd think itd work better on the ground no pressure on the spindles but dont work. got to have her in the air and shell take. hop this helps.
Fred Kobs
09-18-2004 16:56:51
hi, shocker. the gadget that brian g. referred to works great. i think i got mine off the mac truck but believe lisle?? makes it. if you have @ 6" to use it, it'll knock it open. the downside is that also blows the chunks into the piece also. i guess it's better than no lube. good luck fred
s_ontario
09-18-2004 15:49:29
Best thing i ever did was to buy a air greasegun never have to pull a fitting and stick wire into hole again
rustyfarmall
09-18-2004 13:31:10
If it's in an easily accesible area, I like to use my small propane torch. When the grease starts bubbling out, put your grease gun on it and pump away.
RT
09-18-2004 16:42:06
 Re: How to get grease fittings to take grease? in reply to rustyfarmall, 09-18-2004 13:31:10
Me too!I`ve put new zerts in and still couldn`t get it to take grease.But heat that old grease up and pump new in, man it works good.Thats the best way I know, too. RT
old
09-18-2004 12:13:23
I remove them and put them in carb cleaner, then I push some grease through them and reinstall
Brian G. NY
09-18-2004 16:48:30
 Re: How to get grease fittings to take grease? in reply to old, 09-18-2004 12:13:23
I picked up a neat little gadget at a garage sale early this summer. It is a little ram which you fill with grease, apply to the fitting and strike with a hammer. Looks like it should work butI haven't run into one of them tuff B@stards to try it on since I got it.
Rander
09-18-2004 20:52:29
 Re: How to get grease fittings to take grease? in reply to Brian G. NY, 09-18-2004 16:48:30
Whenever possible I take out old clogged Zerk fittings and replace them. I've found that's more time efficient than messing with a clogged one. The fittings are very cheap. I get them online from Fittings and Adapters (link below) very reasonably. You can get almost every size and neck angle in both SAE and metric in small quantities. They also sell a neat little snap on cap that keeps the Zerks from getting dirt and grease encrusted. They work pretty well except on things that rotate at high speed.
http://www.fittingsandadapters.com/greaszerfit.html
