Indydirtfarmer
09-21-2004 05:32:43
Re: Tips needed on buying older tractor for brush in reply to Joe Bard, 09-20-2004 20:02:26
I guess that I'll weigh in on this topic too. With the requirements you have, you're looking at a sizable investment. You're going to want something that will last. You need a tractor that will handle your needs for years to come. That USUALLY means sizing larger than first thought. I'd suggest, like everyone else so far, a minimum of 60 HP. That doesn't mean you have to LIMIT yourself to 60. In this case, bigger MIGHT mean better. BUT...Bigger will require bigger impliments. Then the cost starts to snowball. That's why I recommend a 60 HP tractor. You can still use SOME catagory 1 impliments. That will keep the cost in line on things like scraper blades, box scrapers, ect. You would be able to accomodate a cat1 OR cat2 bush hog. (I ALWAYS suggest 3 point mounted mowers) Independent PTO is, in my opinion, better than Live PTO. I'd tend to favor that option. Diesel is WAY more economical to operate when you're talking 50+ HP. You will need good, modern hydraulics. I personally like R.O.P.S. with canopy, OR a cab. I wouldn't even consider owning a tractor without power steering. M.F.W.D. is a great option, especially on a loader tractor, but a costly one. If you have te choice, a "quick-attach loader" will make your tractor much handier. They do get in the way sometimes. I'm a John Deere fanatic! The are as good as it gets. They also make a great investment. Every Deere I own is worth more now, than the original purchase price.Parts are easy to get. They aren't cheap, but no brand is anymore. As much as it pains me to say, an antique tractor isn't the way to go for your "primary tractor". Newer=dependable, for the most part. Parts will continue to be increasingly harder to find on the old stuff. Another factor would be the dealer support in your area. Look around to see what established dealerships you have nearby. I don't like "orphan tractors" for heavy use. You just never know when the parts are going to run out. Stay with a "current brand" Lastly, you never know what's out there. A good deal just happens. If you go out shopping with one brand, or one model in mind, you will usually pay too much. Find one that you feel comfortable in/on. Not all tractors are designed for big guys. I climbed in a new Kubota last week. A neighbor bought it, and I just had to try it out. It was apparently made for operators around 5'-8", and 175lbs. My 6'-4", 285 frame just didn't work. My head was touching the cab roof, and I just barely fit through the door. Controls seemed like they were "under" me, instead of at my fingertips. Good luck with your acreage. Happy tractoring! John
