Tractor Talk Discussion Forum
1953ish ford 8n
bcd
09-22-2004 20:59:30
I just purchased this tractor and it has a reduction gear with the shifter on the right side of the transmission, in low range the tractor will not move it just grinds and bangs, in high range it will go but about every ten seconds it sounds like it is skipping a tooth or something. Can anyone give me an idea of what might be wrong and what it takes to work on those reduction type transmissions.
Thanks bdc
Steve (Magnolia, TX)
09-23-2004 06:43:55
 Re: 1953ish ford 8n in reply to bcd, 09-22-2004 20:59:30
What Leroy said about production years... (IF it"s an 8N it"s between 1947 and 1952).
If it"s got an auxillary transmission with the shifter on the right side of the housing, then it"s probably a Hupp (which is a bit less common that the Shermans).
You can go to the Smith"s website for full identification hints.
HTH...
Steve
Leroy
09-23-2004 06:01:32
Can't tell you anything about transmission but 8N production ended with 52 and NAA Production started with the Jubille in 53 and in 54 it was just the NAA with number series coming in 55
