Ford Dextra engine torq specs
Mark Hughes
04-19-1999 13:44:06
I'm rebuilding a Perkins 3cyl. diesel engine, & am having trouble finding the engine torque specifications. If anyone can help, I would appreciate it.
Thanks,
Mark
Jerry
04-20-1999 21:29:52
 Re: Ford Dextra engine torq specs in reply to Mark Hughes, 04-19-1999 13:44:06
I should have read the post-ups before I sent message, however if you want a FO-18 manual, call 1-800=757-7627, that's the # for Highlands Tractor, Highlands,Texas. He still has some in the rack, I was looking at them last Friday. Happy motoring to you. Jerry
Jerry
04-20-1999 21:16:30
Here's your torque specs from an I&T Shop Manual::
Rods: cadium nuts 50-55, or locking nuts 65-70-
Mains 90-95
Head: 55-60
Injectors: 40-45 then check for compression blow by, if leaking, completely loosen and try again, may have to tighten more, be sure tube is clean and use new washer.
Valves: both intake and exhaust 0.010 engine at operating temp.
If you have trouble finding parts or need advice call Diesel Parts Co.- Houston, Tex 1-800-683-4439
oil filter is Fram CH813Pl Carquest 85188, Wix 51188. Fuel filter-Carquest 86194, NAPA 3194. Fram C11816BTL
both the 144 and 152 cubic in engines set the same, if you need to know anything else just holler. Oh yeah, address to mail order service manual is I&T Shop Service, Technical Publications Div, Intertec Publishing Corp, PO Box 12901, Overland Park, Kansas 66212.
Good luck on your Dexta, hope this will help, Jerry
Mark Hughes
04-22-1999 10:54:38
 Re: Re: Ford Dextra engine torq specs in reply to Jerry, 04-20-1999 21:16:30
thanks so much for the info....love this discussion group - it is really chock full of good information....it's nice to know there are people out there willing to help someone.
thanks again,
mark
Jerry
04-20-1999 21:19:00
forgot to put in manual it's Manual No. FO 18 at I&T
Tony
04-19-1999 16:35:03
Mark,
The IT shop manual number FO-18 has all the information you need to rebuild that engine and lots more. I think it's available for purchase on this site - I've purchased several manuals and have been very pleased. If FO-18 isn't available, there is an IT collection that covers Dexta. They're great manuals!
Regards - tony
Mark Hughes
04-20-1999 11:34:59
 Re: Re: Ford Dextra engine torq specs in reply to Tony, 04-19-1999 16:35:03
Tony,
Just so you'll know, the FO-18 manual is out of print....If you have any other suggestions, or know where I can find this manual, please let me know.....
thanks,
mark
Mark Hughes
04-20-1999 11:10:46
Thanks, tony for pointing me in the right direction. I'll get that manual, sounds like it's just what I need.
thanks again!
Mark
tony
04-20-1999 16:36:45
 Re: Re: Re: Ford Dextra engine torq specs in reply to Mark Hughes, 04-20-1999 11:10:46
Mark,
Sorry - I kinda suspected that particular manual was out of print, but I swear that I saw a different IT collection on a site somewhere that covered Dexta. It's not here, I just checked, but I'll try to track it down... memory's not as good as it used to be. Anyway in the meantime, if you'll e-mail me a list of the specs you need (just click on my name in the from line), I'll find them in the manual and send them back. They're imbedded in the text and would really help to have a list to check off.
Regards - tony
Ed Burress
06-06-1999 22:29:38
 Re: Re: Re: Re: Ford Dextra engine torq specs in reply to tony, 04-20-1999 16:36:45
I'm about to buy one of these tractors. It's a 63 or 64 Dextra with a 3 cylinder diesel that's pretty tired. We couldn't get it started when I looked at it, but I could see the tire marks in the grass where he had just driven it in. Looks pretty solid, but sounds like a main bearing or more likely a connecting rod is slapping. He wants $1500 for it. Condition otherwise is pretty good, rubber, body, mechanics, etc. New head and rebuilt hydraulics 5 years ago. Where can I buy manuals for this one? I've been all through gas engines, but never even owned a diesel...are they any harder to rebuild?
Thanks,
Ed
Fred Crawford
07-31-1999 22:23:39
 Re: Re: Re: Re: Re: Ford Dextra engine torq specs in reply to Ed Burress, 06-06-1999 22:29:38
I BOUGHT A SUPER DEXTRA THAT WAS RUNNING,BUT SMOKED ALOT ONE YEAR AGO. THIS YEAR IT W/N START WITHOUT STARTING FLUID. I JUST FINISHED THE OVER-HAUL AND IT IS RUNNING FINE. COST WAS JUST SHORT OF 500.00 (I DID THE WORK) THIS WAS MY FIRST DEISEL.THIS IS A PERKINS DIESEL AND I UNDERSTAND THIS ENGINE IS USED IN M/F ALSO.
I WAS ABLE THE GET MANUAL AND PARTS FROM MY LOCALE TRACTOR STORE. IF YOU CANT LOCATE MANUAL INFO LET ME KNOW AND I WILL GET INFO BACK TO YOU.
john colville in Ireland
08-11-2004 14:38:55
 Re: Re: Re: Re: Re: Re: Ford Dextra engine torq sp in reply to Fred Crawford, 07-31-1999 22:23:39
i have bought super dextra it needs engine re build can you e mail the torque settings or if you could e mail the complete manual ive tried and cant get one. a million thanks john
