Tractor Talk Discussion Forum
john deere 1010 injector pump
flb038
09-23-2004 17:45:57
need info on how to time the injector pump on my john deere 1010
Don Mayes
09-23-2004 20:50:09
 Re: john deere 1010 injector pump in reply to flb038, 09-23-2004 17:45:57
Take the cover off of the bell housing on the right side turn the engine over by hand till you see the TDC mark line it up in the center of the hole then take the cover off of the inj. pump it is the little cover about 3/4 by 1 inch inside you will see two lines if there is only one you will have to turn the engine over one time to get it in time if the lines are not lined up losen the two hold down nuts and turn the pump till they line up . Don
