Tractor Talk Discussion Forum
Belarus hydraulics
RayJr
09-23-2004 19:58:20
I have just bought a early 90"s model 310 Belarus tractor. After 3 or 4 uses the 3-point hitch will not lift. Found out it was OUT of fluid. My fault, I knew better than not to check behind the other owner. Anyway I refilled but now it still will not lift. Being a first timer with a tractor, I was wondering if someone could tell me how to solve this. The pump is running and I get "some" pressure but no movement. Is there a way to bleed this system? Help me please!!!
jb
09-25-2004 11:40:17
 Re: Belarus hydraulics in reply to RayJr, 09-23-2004 19:58:20
Ray,
I dont have the solution to your problem but someone at the Belarus forum>Link
You can also try calling Jerry at Beshears tractors at 1-800-541-4215.
Good luck.
